Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
Whirlpool jacuzzi tub power button stuck - Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
5 Suggested Answers
  • 491 Answers
SOURCE: water leaking due to faulty knob on jacuzzi whirlpool
replace rubber wasers
Posted on Oct 10, 2009
Mackmech11
  • 122 Answers
SOURCE: whirlpool jacuzzi tub is not turning on when power
there might be a fuse at the pump that has blown
Posted on Apr 19, 2010
uspartscente
  • 717 Answers
SOURCE: Jacuzzi tub power button not working, can hear it
that is the sounds of a bad air button on the side of the tub.
Posted on Sep 06, 2010
uspartscente
  • 717 Answers
SOURCE: have a whirlpool cadet jacuzzi tub and black slime
You have a bacteria problem. You will need a cleaner to run through your system. some names to search for ... system flush, Jet Clean, Jet Fresh
Once you run the cleaner through your tub that will eliminate the sludge you are getting
Posted on Feb 01, 2011
Jacuzzi majic touch won't turn on
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Nov 28, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Asteria will not turn off
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
Rod
US Parts Center
Aug 23, 2013 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi tub wont power off or on by push switch to turn off or on i have to use power supply
The button is worn out. It should be a relatively inexpensive repair whether you do it yourself or have a technician drop by.
May 17, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
43 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
