Question about Clarion VZ401 VZ-401 In-Dash DVD Player
I cant get my stereo to light up
I added a a relay to bypass ebrake but used power antenna on 85 and grounded 86 and 30 87a ebrake. and one light flashes in the lower right hand corner
I have a 1998 dodge ram I recently replaced the radio antenna and now my stereo does not work and neither do my headlights
The new antenna is not properly grounded, or the power antenna is not a powered one. The radio uses it to ground, or the radio and light circuit needs alternate ground.
Nov 01, 2013 | 1998 Dodge Ram 1500 4WD
E brake bypass think this will work?
Go on amazon.con type in micro bypass and buy the 3 wire relay about $10-12 and fallow directions included
Alpine screens may require a different bypass also found on Amazon
Mar 18, 2017 | Clarion VRX785BT Car DVD Player
Cant view movies with out handbrake on would like to bypass this
you need to ground out the safety wire on the deck to the chassis or find a power wire that is always on like p. antenna. or you could see if that particular deck has a code you can put in so it will allow video while car is in drive or moving. if you had it done at a stereo shop they are required by law to hook it up that way because it is illegal to view dvds while driving
May 06, 2009 | Car Audio & Video
Cant play the dvd player
You need to solder the back pins on the unit. We can do it at www.turbotunes.com
-Steve
Apr 09, 2009 | Pioneer AVIC-N2 Car DVD Player
Bypass ebrake with relay on a pioneer avh-p5700
Go to any auto parts store and purchase a four wire relay and wire it up as follows: The relay will have numbers written on the bottom for each pin. The wire from the parking brake from the H/U to 87. Ground to 85 and 30. Remote from the H/U to 86. This will give you an automatic bypass to the DVD lockout. If you want to just put a switch to do this manually you can also. Go to Radio Shack and buy a momentary push button switch, part number 275-1548. Take the green wire coming out of the unit. Strip the wire, and attach it to one of of the pins on the relay switch. It doesn't matter which one. Buy a standard 16 gauge wire from Radio Shack and connect it to the other pin on the switch, then connect the other end of it to a grounded connection on your vehicle. Now, when you play a DVD, the warning screen will come on. Just press the button on the switch and it will go away, since it tricks the receiver into thinking you have engaged the parking brake. Like someone said before, it is illegal in just about all states to have a dvd or other video playing if the driver can see it and the car is moving. This method is used because the lockout not only keeps you from seeing videos but also locks out some features which many feel have nothing to do with safety and they need it.
Mar 24, 2009 | Pioneer AVH-P4900 Car Video Player
Brake bypass
this is on a website link let me try to find it its a wire buddie had same issuue
Jan 27, 2008 | Pyle PLTDN71 Car Video Player
Ebrake override
Take the E-brake wire coming from the stereo and ground it to any metal part on the car by securing it under a screw.
Dec 01, 2007 | Kenwood DNX7100 Car Video Player
How do i bypass the emergency brake wire on a dual xdvd700
Just ground out the Ebrake wire... it will work fine then. Even if you just link the ground and ebrake wire together and ground them together it works!
Dec 01, 2007 | JVC KD-AVX33 Car Video Player
AVH-P4900 E-Brake ByPass?
my name is derrick and i found out how to bypass the e brake using a relay if you need help email me at derrick_bow@hotmail.com and no you don't need a switch.
Nov 15, 2007 | Pioneer AVH-P4900 Car Video Player
Clarion VZ401 VZ-401 In-Dash DVD Player Logo
14 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
