Question about Midea MDF1-40AEN3-BA5 Westpointe, 40 PT, White, Electronic Con
What does P1 code on MDF1-30AE-BA5 mean - Midea MDF1-40AEN3-BA5 Westpointe, 40 PT, White, Electronic Con
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
Jul 26, 2015 | Dehumidifiers
What is the P1 code on my Dayton Dehumidifier 5eaj9 mean?
Empty the bucket. Reseat the bucket carefully or the code will not reset. This is the only documented action for code P1.
Jun 14, 2014 | Dehumidifiers
What does P1 mean
t appears to mean "defrosting." In other words, the condenser coils have gotten too cold and are icing up..
The filter is probably full, or the thermostat is faulty. Open it up and clean the filter first.
Sep 17, 2012 | Midea MDF1-30AEN3-BA4 WP 30PT ES...
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
What does error code P1 mean?
Hi Mike
P1 is air probe faulty
Regards
Gordon
Apr 20, 2011 | Dehumidifiers
DDR4010E just bought and set up now a couple hours later the display reads:P1. what does that mean?
P1 is code for defrosting. Once it's done defrosting it should start operating
Oct 29, 2010 | Danby Dehumidifier
Code on Top
I have another of their dehumidifiers, the MDF1-30AE. The first time the P1 came on, the unit stopped, because the filter needed cleaning. Recently P1 came on but the unit didn't turn off, and I had already cleaned the filter, so I phoned Midea customer service at 1-866-646-4332. The man told me P1 means it's in defrost mode and said to just leave it on and the P1 will eventually go away. It's been a while though....
Dec 01, 2009 | Midea MDC-45AE Dehumidifier
What does P1 mean on display?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 16, 2009 | Danby Dehumidifiers
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E2 = Not draining
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
Kenmore Dehumidifer P1 Problem...
I heard that the code P1 meant defrosting mode, and it will restart normally after it is done defrosting.
Apr 06, 2008 | Kenmore 53701 Dehumidifier
Midea MDF1-40AEN3-BA5 Westpointe, 40 PT, White, Electronic Con Logo
Top Midea Dehumidifiers Experts
J.D. Browning
J.D. Browning
jasbo
jasbo
 Russ Hill
Russ Hill
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
