Can i rogram my kenwood am/fm kr-796 to a Philips srp5107/27 universal remote
I cant get the input button to work as well as most others. All that basically works are the volume and on/off buttons on the remote.
  • 3 Answers
SOURCE: volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Posted on Jan 23, 2007
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
jerryg50
  • 1667 Answers
SOURCE: Kenwood kr-v9020
You should find out who does the service for your reciever in your area. This type of fault can get fairly involved. It will require trouble shooting and then ordering the necessary parts.
The fault can be the motor, or the electroncs in the servo drive amplifier for the motor.
Jerry G.
Posted on Jun 10, 2008
salsaurbana
  • 56 Answers
SOURCE: mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Posted on Nov 20, 2008
stonephoenix
  • 563 Answers
SOURCE: philips universal remote not working for my coby dvd 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
How do u program a phillips universal remote to a panosonic fm radio model # pv-c1320
Philips Universal Remote control Instructions
  1. Turn on the device (TV, DVR, etc.) you wish to operate.
  2. Press and hold the SETUP button until the red light indicator remains lit, then release the SETUP button.
  3. Press and release the desired mode button (TV, DVR, etc.).
More items...
Philips Universal Remote control codes for TV, VCR, Set-top Box ...
www.directutor.com/.../philips-sru210327-universal-remote-control-codes-tv-vcr-set-top... How to setup phillips universal remote to panasonic tv Google Search ..not sure if it will help you out but have a look.
Nov 29, 2016 | Universal Televison & Video
I have RCA cables , How do I use my computer music ? What connections and settings?
Are you trying to play music off your computer through a stereo or receiver??? If so you will need a cord with red & white (rcas's) on one end & an 1/8" jack on the other...Run it out your headphone jack of the pc (usually color coded light green) and turn input of stereo to corresponding input you plug into..
May 23, 2016 | Kenwood Kr-5600 Vintage 70s Am/fm Stereo...
Remote code for kenwood receiver kr-v86r
If your Bose remote really is universal, you should be able to search for a code that will enable some functions of your Kenwood receiver. The Bose remote may not have a suitable code in its library.
Sep 29, 2014 | Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Unable to program me universal remote
i have a ge universal remote and need a code to program my soyo tv so i am able to turn on and off. could some one give me a code
Oct 10, 2009 | Televison & Video
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Jun 01, 2009 | Kenwood Audio Players & Recorders
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Need codes for philips universal remote on a toshiba TV
i don,t know the code to this remote it is a ge universal remote
Jan 06, 2009 | Philips Universal PH301S Remote Control
Universal remotes
Go to Dollar Store buy remote unit with code Book $5.00.
Jun 28, 2008 | Akai PT4799HD Rear Projection Television
18 people viewed this question
 Grubhead
Grubhead
