Gogear sa10ps16k 02
Locked in "Loading" mode. Reset and Opus Device Manager don't work
ThaMp3Doctor
  • 8596 Answers
SOURCE: GoGear 8Gb
You need a firmware upgrade.
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Posted on Feb 19, 2008
  • 23 Answers
SOURCE: frozen gogear
Try taking a something small(needle,pin)to poke the reset buttin if it has one.
Posted on Sep 27, 2008
SOURCE: Device Manager wont detect my gogear
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
Posted on Jan 23, 2009
YourZEN
  • 820 Answers
SOURCE: i have a philips gogear sa5285/02 it is just
All support for the SA5285/02 is on next page:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA5285/02&slg=en&scy=GB
When the reset was to no avail, see next help information:
http://www.p4c.philips.com/cgi-bin/dcbint/faqview.pl?ctn=SA5285%2F02&dct=QAC&new_tmpl=1&refdisplay=PAV_GENERAL_HANGUP_1&refnr=0073626&scy=GB&slg=ENG
Try resetting from step 1 or try following steps:
In step 2 and 3 the player's content will be deleted !
When needing more help, just add a comment in this reply.
Posted on May 01, 2010
  • 11 Answers
SOURCE: My Philips GoGear Opus(8GB) showed
Philips Support Page
This worked for my Opus player supposed to work for all Opus players.
Tip: if the Device manager asks you to update first, dont, close the dialog and Choose 'Repair' tab. Follow the instructions from there.
You need to connect the player whilst holding the "+" volume key to enter the repair mode
Posted on Feb 20, 2011
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
My mp3 opus cannot find data file says to wait for USB connection
philips support page
Dec 30, 2010 | Philips GoGear HDD1830 MP3 Player
I have mp4 philips GoGear Opus wait for USB Cannection Cannot find data file File Header : 50 48 30 47 30 31 30 39 30 30 Start header : FF FF FF FF FF FF FF FF FF End Header : FF FF FF FF FF FF FF...
Oct 26, 2010 | Philips GoGear SA6185/37 Digital Media...
My Philips GoGear Opus(8GB) showed "Wait for USB Connection, Cannot find data file!" Is there any solution to it?
Aug 07, 2010 | Audio Players & Recorders
My 16 gb gogear froze
1 On your computer, select Start >
> Aria Device Manager > Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
GoGear 8Gb
Feb 18, 2008 | Philips GoGear HDD1850 MP3 Player
 Grubhead
Grubhead
