Question about Archery
Printer will not print
Brothers MFC 6490 CW
  • 3 Answers
SOURCE: My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Posted on Sep 17, 2009
trikha_karan
  • 66 Answers
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
Jimsta01
  • 405 Answers
SOURCE: My MFC 490 cw only prints yellow and magenta. All
You should run a few cleanings. Push the ink button then down arrow for cleaning and push ok.
Posted on Mar 27, 2010
Patzky
  • 240 Answers
SOURCE: My MFC 685 CW will not print.
Hello ,
First, we will have to make sure the printer is properly connected to the network
  1. Go to your printer.
  2. Press “menu” and scroll down to network, then WLAN
  3. Go to TCP/IP
  4. Go to IP address. Make sure there is an IP address here (not 000.000.000.000). Change the last 3 digits to “050”
  5. Change the boot method to “static”
If your IP address is not a valid one (all zeroes) or is an APIPA address (starting with 169.254.#.#) you will need to run the wireless setup wizard again as the machine is not properly connected wireless
If you had a valid IP address before changing anything, it means that the printer offline is caused by the computer not being able to locate the printer.
This is usually caused by the printers IP address changing.
Changing the boot method to static will make sure the IP address on the printer does not change.
Now we will have to make sure the computer knows where to find the printer.
On your computer, go to your start menuè control panelè printer
Here you should see your brother printer. Right click on the printer and select “properties” (If you are running windows Vista, make sure select “run as administrator” and then properties)
Go to the “ports” tab
Select “add Port…” and then double click on “standard tcp/ip port”.
This will bring you to the add port wizard, click next.
In the field for “Printer name or IP address” enter in the new IP address of your printer and then press next and finally “finished”.
Make sure to apply the changes.
You should now be able to print.
Thank you,
Posted on Mar 29, 2010
SOURCE: My Brother Printer MFC 665-CW just came up with a
Just got a new brother mfc -665CW inkjet printer with built in wireless. The moment i just it on, there is a message on the viewer: unable to init. 50
What can i do?
Posted on Jun 21, 2011
Brother mfc 6490 cw wont connect to wireless g router
Hopefully, this article will help:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000028/faq002628_006.html?reg=us&prod=mfc6490cw_all&c=us&lang=en
Apr 14, 2013 | Brother MFC255CW All-in-One InkJet Printer
Brother MFC 6490 CW--have an error message "unable to print 6F" what does that mean and how do I fix it
This indicates one of 4 problems. They are in this order from easiest to most difficult.
1 Malfunction caused by overload (unplug the power cord and wait 5 seconds then plug back in.
Open and close the scanner cover.
2. ASF encoder sensor defective (Replace ASF motor assy)
3. ASF Motor defective (Replace ASF Motor assy.)
4. Main PCB Defective (Replace Main PCB)
If this is any problem other than 1 above you will need an authorized service center.
Good Luck
Mar 26, 2011 | Brother MFC-8440 All-In-One Laser Printer
MFC 6490 CW I installed new colour cartridges, cleaned heads but it wont print in colour???
Hi I'm sorry say your machine will need a new print head and they are not easy to fit my suggestion will be to contact brother by email and ask if they will suggest a repairer in your area
but I would look at replacing it with a canon or a hp
Mar 08, 2011 | Brother MFC 6490CW InkJet Printer
HOW DO I PRINT AN ENVELOPE ON A BROTHER MFC 6490 CW
the plastic indicater should slide back and forth to adjustr from paper to envelope
if you dont have the manual to figure this out , go to this link
http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
leave positive feedback for me please
Oct 16, 2010 | Brother MFC 6490CW InkJet Printer
How to install a Brother MFC 6490 CW printer without a cd
did you try downloading from the brother website (brother.com) they usually have most of them posted there
May 17, 2010 | Brother Office Equipment & Supplies
Mfc 6490 shutdown
Fuse blow?? I wish its not over voltage until the board inside the printer malfunction. If it still under warranty, you better send it BEFORE the warranty end. Maybe you cannot use it temporarily but at least within warranty period you can use it.
May 14, 2010 | Brother MFC 6490CW InkJet Printer
How to use brother mfc 495 cw wireless to my computer do not have manual
i am trying to install the printer software and it is saying it needs to be configured to the wireless router, HOW DO I CONFIGURE IT TO THE ROUTER? I HAVE A BROTHERS MFC495-CW WIRELESS PRINTER.
Apr 23, 2010 | Brother MFC 420CN All-In-One InkJet...
Mfc 6490 CW has no power
Is there power to the outlet?
Are both ends of the Brick (transformer) plugged in properly?
Don
Jan 22, 2010 | Brother MFC 6490CW InkJet Printer
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
Archery Logo
81 people viewed this question
Top Archery Experts
Tom Chichester
Are you an Archery Expert? Answer questions, earn points and help others
