Question about Apple iPod MA446LL/A MP3 Player
Ipod 30gb stopped playing video thourgh the outjack
Ipod 30gb won't play video through composite cable to tv
  • Mel Neilsen
    Mel Neilsen May 11, 2010
    Perhaps did the TV out option on the iPod get changed?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Apple Expert
  • 421 Answers
Please make sure your AV cable works well. You may refer to the part 8 of this iPod tips, it will teach you how to connect iPod to TV and watch the iPod video on TV. It works pretty well for me.
http://www.mac-dvd.com/ipod-tips-and-ipod-faq.html
Hope it helps.
Posted on May 22, 2009
  • mac colar May 22, 2009
    http://www.mac-dvd.com/ipod-tips-and-ipo...
    Hope it helps.
    Hope it helps.
    Scholar:
  • 31 Answers
Eztoo Video Converter supports almost all video formats as source files and outputs many different video and audio formats beyond HD (high definition), including MPEG, AVI, WMV, MKV, RM, MP4, ASF, iPhone, iPod, MP3, WMA, WAV, OGG, RA, AAC, AC3, etc. You can download this software free from here: http://www.eztoosoft.com/video-converter.html For mac users: http://www.eztoosoft.com/mac-eztoo-video-converter.html Hope it helps. Contact me if you have any other question.,Eztoo Video Converter supports almost all video formats as source files and outputs many different video and audio formats beyond HD (high definition), including MPEG, AVI, WMV, MKV, RM, MP4, ASF, iPhone, iPod, MP3, WMA, WAV, OGG, RA, AAC, AC3, etc. You can download this software free from here: http://www.eztoosoft.com/video-converter.html For mac users: http://www.eztoosoft.com/mac-eztoo-video-converter.html Hope it helps. Contact me if you have any other question.
Posted on May 20, 2009
When my blu ray player is on no matter what I do screen still says resolution mismatch, how do I fix it? Pushing play and stop does not help
Unplug HDMI cable. Connect Bluray to tv using composite video cable. You should then be able to access the bluray players menu to set the hdmi output to a setting that is compatible with your tv (see your TV manual for compatible resoloutions. Once set disconnect the composite video cable and reconnect the HDMI cable.
Aug 02, 2014 | Televison & Video
Sony kvj21mf1ak
It sounds like either the TV or the device is trying to do S video instead of composite video.
see if you can change the output type of the media player and make sure that the TV input is not set to S Video.
Nov 19, 2013 | Cell Phones
Which connection do I use for connection my iPod to samsung tv
You will need either an Apple to Component cable as listed here
or an Apple to Composite cable, here.
The Component cable is Hi-Def, the Composite cable is not.
However the composite cable is more universally used for other applications and may come in useful elsewhere.
Mar 21, 2011 | Samsung Televison & Video
Can you hook up ipod touch to a HD TV or media player
Yes. What you need is an adapter from apple, depending on the type of input your HDTV has. If you need composite, generally denoted by a single yellow RCA video connector and two (Red and White) RCA audio connectors, you need this cable: http://goo.gl/OlSDa Please note that Composite is not an HD signal. Although iPods are not able to output a true HD signal, over component (see below), they will output a slightly higher signal. If you require a Composite connection, denoted by three RCA video connectors (Red, Green and Blue, labeled Pr, Y, and Pb, respectively) plus two (Red and White) RCA audio connectors, then you need this cable: http://goo.gl/yk8Zt Also note that video out on iPods is only supported for certain video formats/video playing apps. Before buying a cable, you should most certainly research whether the videos/apps you are playing/using support video out.
Dec 31, 2010 | Apple iPod touch
IPod Classic won't play video with AV Component Cable
I have the exact same problem, having previously tried the component cables. I called tech support who stated that my ipod classic must have some sort of hardware malfunction when otherwise fully functional. I can get sound through the RCA cables, but no video. What gives?
Jul 16, 2009 | Apple Composite A/V Cable for iPod...
Ipod classic works but no sound
This is common among the 30gb Video iPods. If you play your iPod on a Dock,
such as a iHome or other speaker device, for some reason, they like to take the
Mainboard out. Normally, if it's a headphone jack, the problem will start with
sound only playing on one side of the Headphones.
As a start, you can replace the headphone jack and see if it corrects your problem.
If not, you will need to replace the mainboard in your iPod.
Mar 03, 2009 | Apple iPod classic MP3 Player
30GB Ipod Video doesnt play videos
Sometimes the videos will not play because they are not in the proper format. You can check the format by right clicking on the file. I assume that you know that because you watched videos before.
It could also be a circuit board problem. In that case you would have to replace the circuit board. Also, you could check the video output to make sure that you do not have TV output checked.
Dec 02, 2008 | Apple iPod MA446LL/A MP3 Player
DVD plays in black and white
Which type of cable are you using to connect the DVD to the TV?
Composite video - yellow RCA?
Component video - red / green / blue RCA?
S-video?
This problem could occur if you are using composite video and have it plugged into one of the component video inputs.
Alternatively it could be that you are trying to play a PAL (European DVD) source into the NTSC input.
Mar 16, 2008 | Philips Magnavox 42MF521D/37 Television
Ipod classic
You have to roll back the firmware to 1.0.2 in order to get video its the only thing i have been able to find that works and i have been searching for a long time
Jan 09, 2008 | Pioneer AVIC-D3 Car DVD Player
Apple iPod MA446LL/A MP3 Player Logo
178 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
