Question about Polaroid 3211TLXB 32 in. LCD Television
LCD just on stand by
My TV is brand new, I plugged into 120V at home and it does not turn on, neither the remote or the on/off button on the tv. Can you help me? What can do? Thanks.
Martin Lopez.
  • averso Jan 02, 2008
    We turn on the TV on, no video or audio and the green light is on. We cannot turn off the TV when we push the power button on the TV set and also the remote.
Call Polaroid and they will send out a new control panel.  They will schedule a tech to come out and switch out the control panel or you can do it yourself - pretty simple to do.
Posted on Oct 24, 2007
Jvc lt-37e488 will turn on with just a black screen and no noise. THe menus cannot be accessed and the the buttons will not even work to turn off the tv.
You have either a power supply board malfunction or a main board gone bad. If the voltages from the power supply board are all present and correct, then the main board is at fault. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get parts here.
Sep 21, 2016 | JVC 37" Lcd Tv - Widescreen [lt-37e488]
Not able to turn TV on either with remote or on TV. Think it's a faulty cord going into the TV. Any suggestions?
if u have a stand by light on the tv the circit panel insice the tv may have shorted out or check the plug and replace the fuse 13 amp are better,if that dont work contact your nearest dealer.
Oct 30, 2013 | Samsung LN46B550K1FXZA 46in Lcd Tv 1080p
I have a Digistar HD LCD TV model LC-4010D. I have no remote for the TV. When I turn it on, the blue light turns on to show that it has power. But no picture or sound appears. It is currently plugged into...
I'm not familiar with the tv set, however here are some things to try.
It's possible that the tv powers up in stand-by mode, so you'll need to find a way to turn it on completely. See if there are channel +/- buttons on the tv and try them.
If the remote might be necessary, try to see if you have friends/family with a universal remote control, such as a Logitech Harmony, to lend to you for testing. This way you can avoid spending money for nothing on a remote.
Googling on this brand and model gives a lot of negativity though: a lot of problems posting, but no support or even an online manual. Personally I've never heard of Digistar. It might've been a bad investment.
Oct 17, 2013 | Televison & Video
I am looking for the remote code to pair my toshiba 40xf355d tv to my sky hd remote. Can you help?
0156 works for me 3/1/2015
Turn on your Toshiba TV.
Press the TV button on your Sky remote control.
Hold the Select and RED buttons for several seconds until the LED blinks twice then release.
Press the TV button again
Enter the 4 digit brand code: 0156 - the LED will blink twice
Point the remote at the TV and press the Stand by button.
If the television goes into Stand By press the SELECT button to store this code.
If the TV does not go in to Stand by mode, press the TV button and repeat from step 6
Dec 14, 2010 | Toshiba Televison & Video
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Its a tiny 42'' plasma tv which was working perfectly until my grandaughter dropped the remote control and the tv went off and now wont switch on even though the stand by light is on.It wont even turn on...
Try removing the batteries from the remote control, as a button may be stuck and is causing a repeated signal to be sent to the TV, possibly overriding any manual button actions.
Also unplug the TV for a few minutes and then plug it back in. You said that it wouldn't turn on when pressing the channel buttons on the TV, try the power button instead.
Thanks,
Chris
Boise LCD
www.BoiseLCD.com
Oct 08, 2009 | Televison & Video
TV will not come on by using the remote control
I think I have an answer. This comes from someone from the Geek Squad. She said that somehow the TV was turned off at the TV and not the remote and that has reset the system . Try pushing the "STAND BY' button and everything should work as normal. I will find out for myself in the morning. Good luck to us both !
Nov 17, 2008 | Akai LCT2721AD 27 in. LCD Television
Rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
Aug 22, 2008 | Televison & Video
Code #'s for remote control recognition
Turn on the TV, and the Direct TV receiver, then press MENU on the remote, go to the bottom and select PARENTAL, FAVs and SET UP(press the select button in the remote), then go to SET UP and press select, then go to REMOTE, there you will see all the steps to program your Direct TV remote not only for the tv, the dvd player and the home theater as well. Also you will see ALL the codes for a lot of brands of devices including your TV brand. NOTE: don't go to option on the remote that says "RF/IR", you don't need to adjust that.
Aug 12, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Polaroid 3211TLXB 32 in. LCD Television Logo
37 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
