Question about LG LFX25971ST Bottom Freezer French Door Refrigerator
Replace door gasket on lg refrigerator model lfc22740sb
LG LFC22740SB REFRIGERATOR DOOR GASKET REPACEMENT HOW TO.
3 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: I cant find water filter for my LG refrigerator
Call 1-800-673-1262
Posted on Jun 09, 2010
  • 230 Answers
SOURCE: gasket is leaking on LG refrigerator's freezer door
Generally you can just pull off the old gasket when the new one arrives, they sit in a small channel which you can use a thin screw driver to push it into gently, or the other one has a panel that holds the gasket in which needs to be unscrewed to remove the gasket. My best guess would be the first one. It takes time to put the gasket on so be patient when pushing it into the track, a thin blunt tool would be best
Posted on Sep 07, 2012
Door Latch
Larry, I believe you have to remove the inside door frame cover, starting at the top and working your way down. The cover should snap out and away from the door. Next would be the gasket bracket clips. With a flat tip screw driver insert into the seam between the gasket bracket and the door frame and pry out until the clips snap out. Then proceed to remove the gasket from the channel. Catriver.
Jun 13, 2007 | LG LRFD25850 French Door Refrigerator
Model# RT18DKXEW05 parts
Repair clinic has booth door gaskets
the refrigerator gasket is $91.60
The freezer door gasket is $72.95
If the unit is working good it might be worth it to replace the gaskets if unit is in good shape and you only need one of the 2 gaskets I would replace it. if needs both you need to see what a replacement unit costs and make a decision
http://www.repairclinic.com/Roper-Refrigerator-Model-RT18DKXEW05-ID-114014-Gasket-Seal-Parts
Jan 29, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My LG model LRFC25750TT french door gaskets are shot. Any tips on (a) where to order new ones (L & R); (b) how to remove old ones; (c) how to install new ones -- screws to take out or not, tools...
Ok the gaskets should be press in type. No tools just a hairdryer to take out any wrinkles from shipping. And just go slow dont stretch too much. And you can buy from sears parts driect. Just have your model number ready. I hope this helps.
Aug 23, 2011 | LG LRFC25750 Refrigerator French Door
How do I replace door Gasket?
White plastic strip just to the refrig side of the center gasket needs to be removed first, then gasket pulled back enough to reveal gasket retainer. Use a flat bade screwdriver to pop out the white clips at the top and bottom allowing strip to be removed. Now gasket can be easily pulled out of groove. Be careful when re-installing clips to get springs in correctly.
Feb 19, 2011 | LG LFX25960 Titanium Bottom Freezer French...
How do I repair the gasket on my LG refrigerator door?
Both door gaskets are torn at the top, doors not closing. Where can I get new gaskets? How do I install them?
Thanks
Apr 11, 2010 | LG LRFC25750 Refrigerator French Door
LG Refridgerator LFC257060ST Keeps Beeping
Please check whether the doors are aliened properly to the body and if there is a small warp it could result in escaping of cooling resulting in poor cooling of both the freezer and the refrigerator chamber.
The magnetic gasket is the next reason for poor cooling. So please ensure that the gaskets are having magnet attached to the full length. Broken magnetic strip inside the gasket could also result in partial closing of the door leaving behind plenty of gap allowing the cooling to escape.
Just insert a visiting card between the gasket and the body and if you could do so then the gasket is not effective and requires replacement.
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
