Question about Panasonic VIERA Televison & Video
Turn off overscan
How can I turn off overscan on my Panasonic viera plasma tv? Some of the picture at the top and bottom of the screen are cut off.
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
Posted on Oct 31, 2007
dsacco86
  • 1077 Answers
SOURCE: Panasonic Viera 46" plasma~no sound, no picture
I would use the warranty at Bestbuy at that point. Opening up the TV would most likely void the warranty.
Posted on Jun 28, 2009
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
dsacco86
  • 1077 Answers
SOURCE: what does it mean when my plasma tv turns off by
Basically when it turn itself OFF automatically all the time, the TV goes into "Protection Mode". This happens when there is a damaged circuit board inside the need to be replace and turn itself OFF to protect the other ones from being damaged.
A TV service tech will have to look at it to find out which boards need to be replace. There are about 7 different boards in your TV that would cause this problem.
Posted on Nov 02, 2009
Panasonic 42 viera. no remote,and need to turn off overscan. is it possible without the remote?
Only if you can access the menu settings manually. On most new sets the remote is a must for certain functions such as this one.
Sep 29, 2016 | Panasonic Viera Tc-p42x5 42" Inch Flat...
The picture on my 42"
SHOULD BE A BUTTON ON THE PANASONIC REMOTE THAT SAYS "FORMAT" OR "SIZE" OR "WIDE" OR "ASPECT" PRESS THAT BUTTON UNTIL DESIRED PICTURE IS ACHCEIVED.
Dec 17, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic tv turned off, red light blinking and now when I turn it on I now have a portion of the screen from top to bottom with a thick black line with no picture
Wow! EXACT same problem I'm having...4 days later! Did you buy your's about a year ago like I did? Coincedence it breaks after 1 year?! AirForceGeo (in Waldorf, MD)
Feb 17, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Have a black box in the top left corner of tv how can I get
check and see if your tv has PIP (picture in Picture) which you turn on and off with the remote. If you do you have PIP turned on, but not set to any station.
Nov 30, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic VIERA TH-50PX25 DVD offset and blue color My DVD or VCR is offset on the screen ... ...
this Plasma TV working normally for 2 hrs & just stop &showing blackscreen display"chanel not available" I turn TV off & turn it back on again ,. now it have picture with no sound ...please help if any one know what is the problem is ...Thanks
Oct 08, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic viera doesn't display computer correctly
I have had what is fundamentally the same problem. I have a desktop PC that I am plugging in to my Panasonic Viera TX-32LZD80. I am using DVI connection plugged in to HDMI port.
The solution is fairly simple; use the Menu button on the TV remote to get to the Main Menu for the TV and then select Setup which should be the fourth of four options. This will get you to the Setup Menu for the TV for the current channel. Look for the Picture Overscan option, it will very probably be set to On if you have the problem of %5 or so of display being missing on all sides.
Switch Picture Overscan to Off.
This immediately should solve your problem. A note of warning on this is that I suspected this was the problem but when I first looked at the Setup Menu I could not find the Picture Overscan option.
If you are unable to find the Picture Overscan option then trying fiddling with the Aspect settings. You will probably find it set to Auto. Switch it to 16:9 and you should find the Picture Overscan option will be available from the Setup Menu.
Hope it works for you.
Mar 03, 2009 | Televison & Video
Just bought at Panasonic TH-50PZ80U Plasma. On some channels we are getting a static type line across the top. Black and White. Any suggestions on how to get rid of it?
have you checked in the tv menu settings. check that overscan is turned on,as this will slightly zoom in to crop the error out. hope this helps!
Dec 02, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera 37"
I solved it switching on and off the satellite cabled on scart 1, it was like it sent some strange bits of activity, even though being turned off
Sep 27, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
