Question about Aqua Vac Tiger Shark
I have a brand new tigershark qc. Put it in the
I have a brand new tigershark qc. Put it in the pool for the first time and it cleans the bottom, but won't climb the walls or even go up the incline to go into the shallow end. The pool is 18x36. Any suggestions why
  • Anonymous May 23, 2009
    same exact problem !
    called the 1-800 number and left a message
    For $850 you would think it would be flawless !!!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
Defective bring back
Posted on Jun 04, 2015
4 Suggested Answers
SOURCE: Have power to the floating cord but tigershark will not run.
My tigershark would start working then stop 20 seconds to 20 minutes later. I found that the power switch was loosing good connection after self check cycle, I turned it on and off rapidly to hopefully clean the contact! I now disconnect and restart by pulling the power cord. I have run two cycles with no problem> I will replace the switch when I get a chance.
Good Luck
Posted on Jun 02, 2009
SOURCE: tiger shark just doesnt clean very well
I the filter is not very clean the pump will not push hard enough to hold the tracks onto the walls. Try running without filter in a very clean pool for a few minutes to see if it solves the climb walls replace the filter and clean the unit
Posted on Jun 21, 2009
  • 368 Answers
SOURCE: I lent my TigerShark to
If I were in your place I would try it like it is and if it doesn't work well enough I would reprogram it. If it works will enough then when you bring it home no additional programming will be required.
I hope this helps.
Posted on Sep 06, 2011
Tigershark comes out of the water too far
You need to reduce the flow through the impeller - there should be a baffle (something in plastic, round, that will be installed at the top of the shark) in the box that it came in.
May 29, 2014 | AquaVac Tigershark Plus Robotic Automatic...
Where to connect valves
Hook a temp hose up to it, put it in water and see which way it flows. The intake is then connected to the bottom output from the pool.
Apr 09, 2014 | Swimline Hydrotools Sand Filter
Sealing of motor unit RCX40000DC
grease is filter lube can get from pool supply co
Jun 09, 2012 | AquaVac Tigershark Plus Robotic Automatic...
Tigershark cleaner moves in one direction only
bad reverse possible board if motor reverses manually
Jun 02, 2012 | AquaVac Tigershark Plus Robotic Automatic...
When we lift the Tigershark out of the pool after it has finished its cycle it lets go of all the debris it has picked up. We can't find anything in the manuals to help us. It is very frustrating as it...
With the cleaner out of the pool flip it upside down and remove the bottom lid. Inspect the outer case along the seam where the dark and light color plastics meet. If you find cracks patch them with a two-part epoxy made to repair plastics.
You will also want to inspect the outer case return flaps that are directly behind the brushes. Those flaps can come loose or fall out and will let debris out of the unit.
Check the flaps within the bottom lid itself to be sure they are still installed and functioning properly. A twig of leaf can wedge into the hinge and block the flap from closing allowing debris out of the bag.
Finally, inspect the bag for any holes or wear that could allow debris to escape.
One or more of these issues should be the cause and once corrected your cleaner should operate as it should.
John
Aug 26, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Aquavac Tiger shark won't operate
The power supply powers on even when it doesn't output any voltage, so it's kind of misleading. You should have the power supply checked or you can do it yourself if you have a multi-meter, by measuring the output and making sure there is 24V.
Jul 17, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Good Luck
Apr 25, 2009 | Aqua Vac Tiger Shark
Aqua Vac Tiger Shark Logo
388 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
