Question about Suunto CORE Wrist Watch
12 24 change clock hour - Suunto CORE Wrist Watch
How do I set a tcr338 clok? I can change the minute, but not the hour.
Try this,
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button"
2. While holding the Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the Button to set the clock
Feb 19, 2016 | Watches
Clock is 2 hours ahead of actual cst time
If you have an atomic clock/watch that is not showing the right time, you could have one or two separate problems. First, the clock may not be set for the correct time zone. Second, the clock may have a manual switch to adjust the time for daylight savings time. Each of these problems can make your clock display the incorrect hour of the time, especially after you change the batteries and your clock "forgets" some or all of its prior settings.
Check the back of your clock to see if there is a button or switch to set the correct time zone. If your clock appears to be set to your time zone, change the switch to another time zone and see whether the clock moves forward/backward to adjust. Once it has finished adjusting to the new time zone, adjust the clock back to your time zone to see whether it will now correctly reset to display the time.
I have seen atomic clocks that have manual adjustments for these settings as well as ones that adjust automatically other than the time zone. If you provide the manufacturer and model number of your clock, we should be able to provide more detailed instructions.
May 06, 2011 | Watches
HOW DO I CHANGE MY WATCH FROM 24 HOUR MODE TO 12 HOUR MODE?
click on mode or setting option.then you will see the default time.edit it..try to change it using select or any mode available.there you can see 24hr clock and 12 hr clock.select which one you want.if it is in 12 hr then the time will be displaying like eg:7:00am or 7:00pm it means that it is in twelve hours.if it is showing 7:00 or 19:00 it means it is in 24hr clock.
Jan 29, 2011 | Casio W71-1V Wrist Watch
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
How can I set the tide clock
mcdevito75 here, I've never heard of a tide clock or adjustment or timeing for tide cahnges. The tide changes every 6 hours with 45 minutes at the end of that 6 hours rest you could say before the change of the tide. Refer to your local newspaper or fishing supply outlet for tide schedule.
Jun 29, 2010 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I have an antique clock that requires two places to wind it up. Since Daylight Savings Time went into effect, the clock has gone crazy, chiming the hour on the half hour and chiming three hours ahead. What...
With only limited information provided about your type of actual antique clock this symptom has to conclude that your clock is a non self correcting style.
Step one: Ensure clock is striking the hour. during the time of the hour strike quickly move the minute hand to the hour.
Step two: Move to the half hour allow to strike, move hand to hour allow to strike then move the hour hand to align with the correct count.
Step three: Stop the clock until the correct time has been achieved and start clock OR strike ever hour and half hour until clock is set to the correct time.
Hope this tip guides you to a solution for your clock.
r/ David
http://antiqueclock.clockstop.com/
Apr 06, 2010 | Watches
Activate the 24 hr clock function
Press the mode button until you find the setting for 24 hour or 12 hour setting. (It is likely that the message will be abbreviated because of the limitations of the display, so some interpretation may be needed.).
You change the setting by pressing one of the other buttons on your watch - some experimenting may be needed.
Mar 10, 2010 | Watches
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 09, 2009 | Timex 1440 Nylon watch
Set time on Touch Screen Thermo Clock
Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
1. To set the time, touch the clock icon on the upper left corner;
2. Keep touching the screen for longer than 5 seconds, on the hour area;
3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
4. Touch the clock icon again to start the clock;
5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
6. To set the date, tocuh the calendar icon on the left hand side;
7. Keep touching the screen for longer than 5 seconds, on the year area;
8. Touch the year area until you get what you want;
9. Touch the month area until you get what you want;
10. Touch the day area until you get what you want;
11. The screen will reverse to the time display after 5 seconds if no touch.
12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
Hope it helped.
May 08, 2009 | Watches
How to change the hour
Anniversary clock hands can be adjusted directly moving the minute hand clockwise. Do not touch hour hand as this may cause hand disalignment. Carefully move minutes hand with your finger all the way around till you reach desired time.
Do not forget to rate, please.
Mar 09, 2009 | Seiko Clocks Melodies In Motion QXM135BRH...
Suunto CORE Wrist Watch Logo
Top Suunto Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you a Suunto Watch Expert? Answer questions, earn points and help others
