Question about Philips 47PFL7422D/37 Television
Flickering dim picture - Philips 47PFL7422D/37 Television
Screen flickering, dim, lines moving up the screen
If it was new in 2006, it probably is not worth repairing.
Jan 06, 2018 | Toshiba 72HM195 72" HDTV
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
The video display is flickering and not clear how to improve it in my hp laptop
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 06, 2009 | HP Computers & Internet
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Monitor very dim
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 12, 2009 | Toshiba Satellite A135-S4527 Notebook
The display has dimmed, and looks washed out (faded)
Apr 05, 2009 | Toshiba Satellite 4010CDS Notebook
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Defective CCFL backlight may has the following symptom:
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Mar 14, 2009 | Acer Aspire 5630 Notebook
Picture on monitor is distorted
I went to the panel buttons, and then punched the reset for each of the icons on the menu. That restored the display picture to its factory settings. The degaussing did not help the picture, and any stray magnetism is generally automatically degaussed when the computer starts up. As to the flickering of the picture, that is because of the refresh rate. I am using a relatively updated operating system, and the refresh rate has changed somewhat. I also believe the temperature of the computer affects the flickering. I hope this comment helps someone who has a similar problem.
Best regards,
Nov 17, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
Flickering - Toshiba 62HMX84
it could be as simple as the tv feeding back on itself in a dark room.
it is adjusting the light level because of what it sees ambient in the room.
turn on a light near the tv and see if it stays constant now.
Mar 07, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Philips 47PFL7422D/37 Television Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
