Question about Mitsubishi WS-55807 TV
I have a WS-55807 and a bad shadow
Howdy
I have a WS-55807 and after moving it to check some wires today,the screen now has bad shadows. The problem is that the shadows are not red or blue, but grey. What would cause this problem and how can I fix it?
I have reset it to the factory settings and had to do some major convergence work, but it still has the same problem.
Any help would be greatly appreciated.
  • trashman69 May 19, 2009
    wires were never unhooked, so it has to be the lamp adjustment. If words on th screen have a grey to black shadow, which lamp could be the one that got messed up?
    Thanks
    Problem Solver:
  • 6 Answers
Either you crossed some wires or you jared the lamp adjustment so it is not projecting right!
Posted on May 19, 2009
Ws-55807 green shadows and seems like one color is out. How do I fix
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 16, 2016 | Televison & Video
Ws-65611 color shadows
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
Aug 21, 2012 | Mitsubishi WS-65611 65" Rear Projection...
My Mitsubishi HD1080 series screen is coming inward from the top & bottom.. and occasionally red & green lines or black lines will flash through it... It started out just being inwards once in a...
You have either bad convergence ICs or just bad grounds on the IC. I would go ahead and replace the ICs and check those small ohm resistors, as you have to pull the signal board out anyway. For futher instructions see the website www.TvRepairKits.com. They may have what you are looking for. Be sure you have the TV model number next to you. Thanks for asking and show a few hands of support!
Nov 07, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi 1080 WS-55807 has lost the picture
Unplug the set, remove all other audio/video components, go open front door, and roll it out to the curb.
Nov 24, 2008 | Mitsubishi WS-55807 TV
Blue shadow
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple do the above
Sep 18, 2008 | Mitsubishi WS-55807 TV
Mitsubishi VS 50805/60805 blue/yellow shadows on screen
Aug 17, 2008 | Mitsubishi WS-55807 TV
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Nov 29, 2007 | Mitsubishi WS-55809 55" Rear Projection...
WS-55807: Images are dark on right side of display, but will go away after 3-4 hours.
you could be on the right track get some freeze spray and go around all the parts to see if you can make it act up, same with heatgun or hair dryer when first turned on heat one area at a time to narrow your problem down
Oct 21, 2007 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807
You have a convergence problem, and the sooner you get the set into the shop the less it will cost you. It seems that you may only have bad or cold solder connections on the stk convergence ics. If you keep hitting it to fix it, its goingg to surge the parts then youll be looking at 300 bucks or more to repair. GET THAT SET IN ASAP. Good Luck
Jul 13, 2006 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
