Question about Broderbund PrintMaster Platinum Version 18
Printmaster 18.1 will not download on windows 8. Microsoft.NET Framework 1.1 issue
4 Suggested Answers
SOURCE: windows vista will not bring up my Printmaster 18
Right click on the icon which launches the software, Properties, Compatibility tab, and change it to XP.
Posted on Aug 22, 2009
  • 154 Answers
SOURCE: platinum 18 willl not open. Says I may need to
this is more than likely an issue witht the disc that the file is located on. I would contact the manufacturer and see if there is any way to get a replacement disc.
Posted on Apr 02, 2010
  • 3 Answers
SOURCE: I installed window 7 into
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
Posted on Sep 12, 2010
Can not get printmaster silver to work on windows 10. what do I do
You never will.
This is what the maker of the software said for Windows 8....
Unfortunately this program is not supported on Microsoft's new operating system Windows 8.1 as it requires .Net Framework 1.1. There are currently no updates available as Microsoft is no longer supporting .Net Framework 1.1.
Windows 10 also doesn't have Net Framework 1.1.
If you have recently purchased it, then you can get your money back. Otherwise revert back to Windows 7.
I myself have stuck with Windows 7. I look on Windows 10 as a virus!!!
Jan 26, 2016 | Computers & Internet
Have printmaster silver 16 can not get it to load on windows 10. the disk goes half way and it comes up data. my disc is old but it downloaded on windows 8
Unfortunately it will work with Windows 8, but not 8.1 or higher.
Broderbund who make it sate:
Windows 8.1 .net framework compatibility
Unfortunately this program is not supported on Microsoft's new operating system Windows 8.1 as it requires .Net Framework 1.1. There are currently no updates available as Microsoft is no longer supporting .Net Framework 1.1. If the purchase is within the time frame for a refund then it can be.
Presumably Windows 10 also doesn't use Net Framework.
So if you stick with Windows 10, which personally I think is ****! Then you will have to get a new software for it. As this is toast!!
Jan 13, 2016 | Computers & Internet
Unable to download from disc Printmaster v.18.1 despite being led to believe its compatible with Windows 8
Printmaster 18.1 is not really compatible with Windows 8. Here's a link to a possible solution directly from Broderbund. You can try it, but you might be out of luck.
Printmaster 18 1 Platinum
Feb 28, 2014 | Mindscape PrintMaster Premier 7.0
I can not get my Printmaster18.1 to work on window 8? I keep getting error 1603 and it will not work at all. What do I do?
this is because it not for windows 8 only upto windows 7 32bit.. win8 has a different .NET Framework 1.1 its called 2.0. and net framework 1.1 cannot be installed on win8 hope this helps.
Jan 15, 2014 | Broderbund PrintMaster Platinum Version 18
My wife has been using Printmaster for years and has created thousands of projects. Her latest version is 18. We got a new computer with Windows 7 and it said that version 18 is not compatible. So we...
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed. If possible download .NET framework 1.1 If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
Feb 18, 2011 | Broderbund PrintMaster Platinum Version 18
Platinum 18 willl not open. Says I may need to reinstall printmaster and I am missing microsoft(r).network framework v1.1 Tried to reinstall printmaster and still doesn't work.
Apr 02, 2010 | Broderbund PrintMaster Platinum Version 18
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
Vista error codes 643 and 646
the error codes that you have mention is related to windows update of Microsoft .net framework.
To troubleshoot this issue, I suggest we first perform these steps:
Step 1: Download Microsoft Windows Installer CleanUp utility
1. Visit:
2. Save the file to your computer.
3. Right click "msicuu2.exe", click "Run as administrator" and follow the
wizard to install this tool on your computer.
Step 2: Remove .NET Framework
1. Click Start ->All Programs->Windows Installer Clean Up, click Allow.
2. See if you can find .Net Framework software. If so, remove them.
After that, please restart the computer and perform the following
suggestions to reinstall .NET framework 1.1 and the updates for it.
Step 3: Install .NET Framework 1.1 Redistributable Package and related updates
1. Please download the Microsoft .NET Framework Version 1.1 Redistributable
Package from the following link and save it to the C drive (C:\)
1) Microsoft .NET Framework Version 1.1 Redistributable Package
http://download.microsoft.com/downlo...6/dotnetfx.exe
2) Microsoft .NET Framework 1.1 Service Pack 1
http://download.microsoft.com/downlo...867460-X86.exe
3) Security Update for Microsoft .NET Framework, Version 1.1 Service Pack 1
(KB928366)
http://www.download.windowsupdate.co...d81a178b15.exe
4) .NET Framework 1.1 Service Pack 1 SYSTEM.WEB.DLL and MSCOREE.DLL Security
Update for Windows Vista (KB929729)
http://download.microsoft.com/downlo...929729-X86.exe
Please follow the steps above and if still problem persist please lets us know
Regards,
Om
Oct 20, 2009 | Computers & Internet
I have been trying to download the drivers for Lexmark printer Z53 for a week. I've tried several times on two different computers and keep getting error "message 1603 error installing Microsofft.net...
Windows Update error code "0x643" and Windows Installer error code "1603" are generic error codes. Typically, these error codes mean that the update was not installed. These errors codes are usually caused by a corruption in the .NET Framework installation or by an inconsistency on the MSI database state.
Method 1: Manually remove and reinstall .NET Framework loadTOCNode(2, 'resolution'); To manually remove and reinstall the .NET Framework, follow these steps:
  1. Remove the .NET Framework.
    1. Click Start, and then click Control Panel.
    2. Double-click Add or Remove Programs.
    3. Note each version of the .NET Framework that is already installed on the computer. Then, uninstall all the versions of the .NET Framework.
    4. When you are prompted, restart the computer.
  2. Use the Windows Installer CleanUp Utility to clean up the MSI database state for all the versions of the .NET Framework.
    1. Download the Windows Installer CleanUp Utility. The following file is available for download from the Microsoft Download Center:
      Download the Windows Installer CleanUp Utility package now. (http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe)
      For more information about how to download Microsoft support files, click the following article number to view the article in the Microsoft Knowledge Base: 119591 (http://support.microsoft.com/kb/119591/ ) How to obtain Microsoft support files from online services Microsoft scanned this file for viruses. Microsoft used the most current virus-detection software that was available on the date that the file was posted. The file is stored on security-enhanced servers that help prevent any unauthorized changes to the file.
    2. Install the Windows Installer CleanUp Utility as an administrator or as a user account that is a member of the local Administrators group.
    3. Click Start, point to All Programs, and then click Windows Install Cleanup.
    4. In the Windows Installer CleanUp Utility, remove all Windows Installer applications for the .NET Framework.
  3. Restart the computer.
  4. Download and then reinstall all the versions of the .NET Framework that were previously installed on the computer.
    To download the .NET Framework 1.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=d7158dee-a83f-4e21-b05a-009d06457787&DisplayLang=en) To download the .NET Framework 1.0 Service Pack 3, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=6978D761-4A92-4106-A9BC-83E78D4ABC5B&displaylang=en) To download the .NET Framework 1.1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=262D25E3-F589-4842-8157-034D1E7CF3A3&displaylang=en) To download the .NET Framework 1.1 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en) To download the .NET Framework 2.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en (http://www.microsoft.com/downloads/details.aspx?FamilyID=0856eacb-4362-4b0d-8edd-aab15c5e04f5&DisplayLang=en) To download the .NET Framework 2.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=79BC3B77-E02C-4AD3-AACF-A7633F706BA5&displaylang=en) To download the .NET Framework 3.0, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=10CC340B-F857-4A14-83F5-25634C3BF043&displaylang=en) To download the .NET Framework 3.0 Service Pack 1, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=EC2CA85D-B255-4425-9E65-1E88A0BDB72A&displaylang=en) To download the .NET Framework 3.5, visit the following Microsoft Web site: http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en (http://www.microsoft.com/downloads/details.aspx?familyid=333325FD-AE52-4E35-B531-508D977D32A6&displaylang=en)
  5. When you are prompted, restart the computer.
Note When you have reinstalled all the versions of the .NET Framework, you can use Windows Update to check for updates to the .NET Framework.
Dec 02, 2008 | Office Equipment & Supplies
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
Broderbund PrintMaster Platinum Version 18 Logo
37 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
