Question about Caroma Home
Leaking outlet pipe on my caroma uniset 6-3
The plastic pipe from the tank to the toilet bowl the washer is leaking.
  • 44 Answers
SOURCE: Possible toilet leak or doesn't stop running...
this sounds like the ballvalve needs replacing & the hissing is the sound of water as the valve is not shutting off properly.
The valve at the bottom of the tank is possibly just a half turn valve so try that & see if it stops the water.
The water leaking could be thatthe water level is too high & leaking around the handle assembly & running down, so it kinda looks as though its leaking below?
The handle assembly may of come adrift so thats whay the handle may look loose ?
Solution sounds quite straight forward, a new ballvalve assembly needs to be fitted & the handle assembly sorting.
The leak will be rectified when you replace the old ballvalve, as you will need to turn off the water to the unit to remove the ballvalve, whilst the water is off a service valve should be fitted so as any future probs or servicing needs doing then it can be isolated without the need for turning the whole house off?
This work should be carried out by a registered plumber & is as i said a straight forward job.Price approx £65.00 subject to a survey by the plumber.
I hope this has helped
kindly
Richie
Posted on Dec 17, 2008
  • 659 Answers
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Posted on Apr 11, 2009
whytfang
  • 170 Answers
SOURCE: correct tank to bowl gasket for Orion toilet
I would change out the flush valve itself...it will come with the right gasket....it won't cost anywhere near the price of a new toilet...and it will save you time in the long run..good luck and.thanks for rating my effort....the fang.
Posted on May 01, 2009
  • 10 Answers
SOURCE: When i flush the toilet, the bowl doesn't fill
there is an ajustment on top of float assembly
to adjust level of water in tank
Posted on Nov 01, 2009
  • 2841 Answers
SOURCE: hi, i have a caroma duel flush toilet possibly 10
First make sure it is not overfilling. The water level must stop before it reaches the overflow pipe. If it continues to run it will overflow into the bowl and continue to run. Adjust the fill level to the mark inside the tank. Make sure nothing is getting under the flapper and holding it open. You replaced the flapper so we know that is not the problem. Just make sure the flapper is centered on the drain hole.
Posted on Jan 09, 2010
How do I remove a slow close toilet seat from a Caroma Carvelle one-piece dual flush toilet
All toilet seats are done one of two ways;
A plastic or brass bolt underneath are the rear of the bowl.
A removable cap on the top rear of the seat base.
spec sheet is here
http://www.caromausa.com/database/files/library/Caravelle_Smart_One_Piece_Spec_Sheet_989900.pdf
Caroma website, Installation instructions and Contact details.
Caravelle Smart 270 One Piece Toilet
Dec 13, 2017 | Caroma Home
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
New toilet 540 fluidmaster water in tank keeps topping off every half hour
The problem may be the flapper that seals between the tank and bowl is leaking or the overflow pipe may have a crack in it. I wouled replace the flapper first and check the overflow pipe for cracks.
Hope this helps.
Bob
Oct 08, 2014 | American Standard Home
Caroma toilets repair
have to know whether you mean water is flowing into the bowl?, or "over-filling" the tank? Could either be a bad flapper(More common), or the "fill-valve" is leaking.
Aug 24, 2014 | Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Water leaks from tank to bowl all the time
It is most likely the flush valve gasket. This is the equivalent of a flapper on a normal toilet. You can purchase these seals at plumbingmall.com 750017 Outlet Valve Seal for M5 Flush Valve
Aug 06, 2013 | Caroma Sydney Smart 270 Elongated Dual...
I have a 1998 Caroma Reflections cistern p/n 6871774. It is making a hissing noise after the tank is refilled, and water streaks down from the supply rim of the bowl. Which part needs to be replaced?
the inlet washer needs to be replaced to stop the overflow, the washers are easy to get and cheap but trying to get the unit open to replace the washer is my big question at the moment
Jan 10, 2010 | Caroma 270W-RF Reflection Round Front...
Hi, i have a caroma duel flush toilet possibly 10 years old, it is leaking into the bowl and then constantly re filling, i replaced the washer/ring/ thing at the point where the water exits into the bowl...
Jan 09, 2010 | Caroma 270W-RF Reflection Round Front...
How do I install a gerber 21-375 Toilet? It came with no instructions.
The Gerber Ultra Flush Back Outlet toilet, that uses 1.1 Gallons of water to flush?
Just like any common toilet. Install the tank to the bowl of the toilet, set the toilet, install the flush mechanism in the tank, attach the supply line.
1.MAKE SURE you put the two plastic U-shaped spacers on the back of the bowl!
2.Install the round rubber gasket in-between the tank and the bowl.
3.Set the tank down on the bowl. Make sure you have the round gaskets that go up under the bolt heads, then insert the two bolts into the tank, and through the bowl. NOT installing these will cause a leak!
Tighten these bolts down, until the nuts are JUST touching the tank. (There is a flat washer that goes under each nut)
DO NOT tighten one bolt all the way, then tighten the other bolt!!
These bolts MUST be tightened evenly. Tighten one turn on one bolt, then go to the other bolt.
DO NOT overtighten, or you will break the bowl, and/or the tank!
Make sure your toilet flange on the sewer pipe is in good repair, and clean, from the old beeswax ring. It can be messy, even using gloves. Use a flat painters stick to help remove the old wax ring. Scrape off into a old can. The wax thin residue on the floor and flange is fine.
Set the new wax ring in place, remove the plastic liner that comes with the ring. DO NOT leave that thin plastic liner! It's just to install that wax ring!
Install the bolts that hold the bowl to the floor, or reuse the old bolts if they are in good repair.
Tighten EVENLY, and don't overtighten! You can crack the bowl.
Now install the toilet mechanism in the tank.
Here is a 1 Page, Tank to Bowl Installation Guide from Gerber. It is a PDF file. Let it download ALL the way before looking at it.
http://gerberonline.com/fileLib/Toilets%20Ultra%20Flush%20IS.pdf
Should this direct link not work for you, here is the page it came from,
http://www.gerberonline.com/Catalog.aspx?categoryID=2204&itemID=3514
It's on the right side -> Installation Instruction (PDF)
Jul 02, 2009 | Gerber Blades Gerber Ultra Flush White ADA...
Home Logo
119 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
