Question about Hardware & Accessories
Need to assemble mad gab timer
Kids opened the timer for mad gab and i don't know how it goes back together
talk2ginny
  • 34 Answers
SOURCE: i took the tension apart for a kenmore 148.15600 model
Hi - unfortunately, putting the tension back together takes alot of training - not only do you have to re-install the parts correctly so the hook is in the correct position and the bobbin is in the correct position when the needle moves down thru the needle plate and into the bobbin case to pull up the bobbin thread. Further, you need to set what called the timing - your needle needs to enter the bobbin dead on center and to a very precise depth. Technicians often use a special tool to set the timing, because each machine has a different a different hook and bobbin case.
I know this won't win me any points, but you will probably need to take the machine to a repair shop to have the hook replaced or reinstalled. If you mechanically inclined, you can search the web for a service manual for your machine - the service manual will illustrate how to replace the hook and specify the timing and needle depth settings.
Good luck,
Ginny
Posted on Jan 31, 2009
tzweeb
  • 318 Answers
SOURCE: lid switch assembly
go to www.searspartsdirect.com for a picture of this units lid switch.it doesnt show it very well, but it will give you an idea of how it goes back together.
what you need to do is put the lever around the switch first, then put the plastic box on the switch and arm. then carefully hold the assembly together and try to get it under the top and put the 2 screws back into the housing holes.
it sounds simple but i have done this before and its not easy. you just need to be careful to get the screws into the mounts correctly or it wont hold together to allow the switch to activate when the lid is closed.
by the way was there a reason you took the switch off??
maybe because it wont spin?
by the way this unit is not 30 years old, maybe 20 at the most.
the drive couplings are a weak spot for these and you may have a broken one. it wont spin or agitate but will drain if this is broken.
VtToolMan
  • 704 Answers
SOURCE: I need to know how to put the pump assembly back
Go to the link provided below and under the heading "Browse Subcomponents" click on the "Pump and Motor Parts" link. I think that shows what you're looking for. Otherwise, check the other diagram links for your model on the same page.
Hope this helps!
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=6651514590&pop=flush
Posted on Jul 28, 2009
  • 13 Answers
SOURCE: rules for playing Mad Gab
  • 1.Play begins with the team that has the youngest player on it.
  • 2.Choose one player from each team to be a "reader" while the opposing team chooses someone to be the "stealer." All players will take turns being "readers" and "stealers.
    • 3.Take three Mad Gab cards from the box. The reader is the only one who does this.
    • 4.Show the three cards' answers, without looking at them yourself, to the opposing team with the exception of the stealer.
    • 5.Play starts when the opposing team flips the hourglass timer.
    • 6.Read out the clue, repeatedly, to your team while the timer is going.
    • 7.Shout out suggested phrases or ask the reader to read the clue faster or slower while the other team listens. If the phrase on the card is correct the team that is not answering confirms that the answer is correct.
    • 8.Time is up when the timer runs out. If there are any unanswered Mad Gab cards then the "stealer" from the opposing team gets the chance to try and answer the questions.
    • 9.Scoring takes place as follows. The "reader" counts the Mad Gabs solved by his or her own team and moves their playing piece counter clockwise through the board that many places. The "stealer" does the same if he or she has answered any Mad Gabs for their team.
    • 10.Following the instructions on the oval that you have landed on, on your next turn.
    • 11.Winning occurs when one team lands on the finish oval.
    • Posted on Apr 25, 2012
      • 44327 Answers
      SOURCE: need to put back together push rod assembly
      mic with calipers or micrometer think both ends are the same
      Posted on Apr 10, 2015
      What words can I make from these letters ddamilmvcubrgk
      Baldric
      Buckram
      Cambium
      Cadmium
      Garlic
      Radium
      Karmic
      Vulgar
      Labium
      Burial
      Barium
      Ribald
      Bridal
      Uracil
      Bardic
      Lumbar
      Gravid
      Vicar
      Baulk
      Druid
      Grail
      Umbra
      Curia
      Cigar
      Cavil
      Caulk
      Valid
      Braid
      Brick
      Ducal
      Laird
      David
      Rumba
      Acrid
      Mural
      Crumb
      Umiak
      Album
      Lucid
      Climb
      Amuck
      Build
      Lurid
      Rabid
      Viral
      Micra
      Rival
      Magic
      Guard
      Guild
      Claim
      Black
      Blur
      Bird
      Burg
      Brig
      Bark
      Rial
      Balm
      Card
      Bilk
      Murk
      Mild
      Maul
      Crag
      Mark
      Mica
      Lira
      Limb
      Balk
      Lick
      Arum
      Liar
      Laud
      Lark
      Lard
      Lamb
      Alum
      Calm
      Lair
      Laid
      Arid
      Marl
      Lack
      Amir
      Buck
      Curb
      Bald
      Maim
      Rail
      Calk
      Drum
      Crud
      Crib
      Iamb
      Drag
      Mail
      Lurk
      Ruck
      Grub
      Grim
      Grid
      Curd
      Gram
      Magi
      Grad
      Grab
      Glum
      Glib
      Glad
      Girl
      Gird
      Gild
      Vial
      Brag
      Maid
      Clad
      Bard
      Amid
      Milk
      Cram
      Duck
      Crab
      Luck
      Dual
      Imam
      Rick
      Drub
      Dram
      Brad
      Drab
      Diva
      Dirk
      Avid
      Acid
      Brim
      Dial
      Rack
      Daub
      Dark
      Back
      Uric
      Raid
      Curl
      Muck
      Clam
      Garb
      Burl
      Bail
      Club
      Baud
      Bulk
      Arc
      Dig
      Dud
      Rig
      Car
      Did
      Cub
      Dam
      Gar
      Gal
      Dab
      Mag
      Mad
      Mac
      Lib
      Mid
      Cam
      Rad
      Irk
      Mil
      Cad
      Aid
      Cur
      Mug
      Mud
      Bur
      Ilk
      Dug
      Bug
      Gad
      Lam
      Vim
      Cud
      Air
      Via
      Lad
      Dad
      Mar
      Rub
      Lag
      Lab
      Rum
      Rug
      Big
      Bid
      Gum
      Rim
      Alb
      Rid
      Lug
      Dub
      Rib
      Bar
      Ram
      Lid
      Bud
      Rag
      Bag
      Bad
      Add
      Dim
      Auk
      Mum
      Arm
      Ark
      Ail
      Cab
      Aim
      Lac
      Gab
      Kid
      Ma
      Am
      Mi
      La
      Um
      Id
      Mr
      Mu
      Bi
      I
      A
      Oct 19, 2014 | Toys
      I'm looking for the story booklet that goes with the pressman MindTrap An unsavory demise jigsaw puzzle
      Well, if you live in a house, here is what you do.
      1. Search the attic. Attic\'s are where little kids love putting things when you play Hide and Seek with them. It really depends on how long you\'ve had the puzzle.
      2. Now for the basement. The basement, attic, the same thing. Sometimes you use a basement if you don\'t have an attic to put your trash in, or sometimes, you have both if you run out of space in one.
      3. Your little kid\'s room. Ok, admit it. About every day, new babies are being born, and people who were once babies are dying. Kids sometimes play with you if you make them mad or if they are just the cute and playful type.
      4. Check your room. Admit it. Even as a teenager, you have so much to deal with, you absolutely forget the fact that - well, you still play with puzzles. So what better to do than check your room? After a night out with your friends, or something, or babysitting someone\'s kids, or doing so much homework, or maybe even taking care of your own kids, you forget where you put things. So please, I\'m begging you, check your own room.
      5. If you live with your parents, check the trash or the dump. Admit it. Once in a while, your Father (if you are a boy) gets worried that you\'ll never join the baseball team or any other, or maybe (if you are a girl) guys won\'t like you ever and you\'ll never move out of the house because your Mother let\'s you be so sensitive and play puzzles for happiness. Or your Mother (if you a girl) worries that you\'ll get your heart broken when your date finds out you still play with puzzles at your age, or (as a boy), your Mother worries if you still never leave your puzzles, they throw it away! So check the trash before you post any more problems on fixya\'.
      Dec 30, 2013 | Pressman Toy MindTrap Mystery Puzzle; An...
      How to disable drivelock password.I don't know the password. It was inadvertantly set by one of my kids.
      Unless you set a master DriveLock password to reset it with, then (according to HP at least) the hard drive will be rendered completely unusable. I think your best bet would be to try and get your kids to give you the password.
      Oct 22, 2012 | Compaq Presario 2140US Notebook
      Rules for playing Mad Gab
      • Apr 23, 2012 | Mattel Mad GabĀ®
        GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
        Find the Hot wire:
        Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
        Connect wires:
        Hot wire goes to Black timer wire
        Wire to load goes to Red timer wire
        White wire connects to white wires that are twisted together
        Bare copper wire connects to Green wire from timer
        How to connect white wire to white wires that are twisted together.
        a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
        b) Remove wire nut. DO NOT UNTWIST wires.
        c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
        d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
        e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
        Sep 25, 2010 | UPM Programmable Wall Switch Timer
        Timer knob assembly, how to disassemble and assmble back together
        It sounds like the only thing you are missing is the circlip to hold the whole lot together.
        With it de assembled you should see a cut out part on the timer stem that's where the circlip goes when it's all back together
        Jun 11, 2009 | GE Washing Machines
        Dryer switch
        yeah but its unsafe specially with kids! it could stay running if the door was open and wont stop unless you turn the knob or unplug it. thats if it was bypassed.
        Apr 17, 2009 | Whirlpool LER4634J Electric Dryer
        Hardware & Accessories Logo
        140 people viewed this question
        Top Hardware & Accessories Experts
        Gene Haynes
        Hippy_dd
        Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
