Question about Samsung LE26R74BDX 26 in. HD-Ready LCD Television
I have a samsung LE26R74BD 26" screen about 6 year old. Three months ago after not being use for 10 months we started using it again. After a few days of use it was left on standby for around 24 hours
Samsung had this investegated with Martin doors, who said it was the power supply. My question is:- 1) how much to repair this? 2) would this have court fire???
SOURCE: spn4235 42" Samsung Plasma 6 years old
you can get the power supply and/or the service manual (with schematics included) here.
http://www.samsungparts.com/search/search.asp
Posted on Jun 22, 2008
SOURCE: Samsung HP-R4252 42 in. HDTV screen black outs and red lines
Hi: We had this problem under warranty, and tech installed the following to solve it: Parts BN96-02033A, BN96-02034A and BN96-02216A. This solved the problem for 2 years. I now have the upper half going black now and then for 2 to 3 seconds. I am ordering these parts from www.partstore.com and will just plug them in. Better than a new tv.
Posted on Aug 16, 2008
  • 11 Answers
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
SOURCE: Samsung LE40R73BD Will not switch on
I found a fix for this problem on another forum, It's caused by some blown capacitors on the main power board. I have a link to the original post, with step by step pictures for replacing the blown capacitors but don't know if it's ok to post it here. The repair cost me £7.49 for 5 capacitors RS part number 526-1109 and about £4.50 of that was for next day postage. I did the job myself in about 15 minutes and I have no experience with a soldering iron (i even had to borrow one). I replaced 3 capacitors, 2 of which looked blown and one which just looked swollen.
Remove the back off your tv, and just take a look at the small array of capacitors near the top right corner of the centrally situated power board. there are 4 identical capacitors rated at 1000uf 10v 105 degrees C. I think the silver capacitor lids should be flat or even slightly concave. The ones I replaced were all slightly convex and 2 of them had a tiny amount of what looked like brown corrosion right in the centre of the caps.
For a few quid I'm sure you could get someone else to do the soldering if you lack confidence.
The original post also linked to a supplier of the main power board for £130. I didn't mind having a go myself because I figured if I fouled up I could always just buy the board.
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
How to replace defrost timer
a bad defrost timer can be checked with a multi meter
Sep 08, 2014 | Whirlpool Refrigerators
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Electrical problems
Are these factory OEM replacements? I once put three cheap aftermarket Kragen batteries in my Corvette in 6 months, bought a Delco and problem solved, that was years ago. Sounds like your problem is that the car sits to much, if it sits more a few weeks either hook up a float battery charger or disconnect the negative cable to the batt.
Feb 02, 2012 | Cars & Trucks
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and again.no sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Mar 17, 2010 | Televison & Video
93 Chev.c1500 won't kick over
It could be the temp sensor switch. Fuel injected engines (most GM models) use the temp sensor as the choke sensor as well. I had a Buick that did the same thing and replaced temp sensor and worked fine thereafter.
Feb 15, 2010 | 1993 Chevrolet C1500
Siemens Condensor Dryer E46-38. After a few
Mine is 4 years old and the pump went within 8 months! The dryer has had 6 new pumps in total! It was last fixed 6 months ago and now playing up again! I dont even constantly use my dryer! I am very disappointed with Siemens now, my last dryer lasted me 10 years and it was constantly on the go when my children were young! Here comes, tomorrow I have got to book another repair! No more Siemens for me.
Oct 20, 2009 | Siemens Dryers
Small white dots are emerging all over my Samsung DLP TV - 46`
Bad Light Engine,Call UED for price of rebuilt one!
1-800-648-6657 TIP if you have never replaced color wheel,they 9/10 go bad also!
Sep 28, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung LE26R74BDX 26 in. HD-Ready LCD Television Logo
Jerry Greenberg
Jerry Greenberg
