Question about BellSouth Digital Answering System 2006C Digital Answering Machine
Change the number of rings before answering machine picks up
KX-TG5621C changing number of rings
The KX-TG5621 isn't an answering machine. It will ring until you answer, some answering machine picks up, or the caller hangs up.
To change the ring count on your answering machine, refer to the documentation for that answering machine. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Oct 17, 2014 | Lands Phones
How do I change the number of rings on this phone?
The KX-TG2313 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count, refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jul 15, 2014 | Panasonic KX-TG2313 Cordless Phone
CHANGE THE NUMBER OF RINGS ON THE VTECH CS6719-16
The CS6719-16 isn't an answering machine. It will ring until someone answers, some other answering machine picks up, or the caller hangs up.
If you want to change the number of rings before an answering machine picks up, please reply to this post and specify the answering machine.
Apr 08, 2014 | Vtech CS6719-16 Cordless Phone with Caller...
How do I change the number of rings before answering machine picks up Vtech cs6619
The CS6619 isn't an answering machine. It will ring until you answer, an answering machine picks up, or the caller hangs up. To change the ring count on an answering machine, please refer to the documentation for that machine. If you require further assistance, please add a comment to this question and identify the answering machine.
Feb 17, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How do I change the number or rings on my vtech cs6619-2
The CS6619-2 isn't an answering machine. It will continue to ring until someone or something picks up, or the caller hangs up.
To change the number of rings before your answering machine picks up, please consult the documentation for your answering machine.
Dec 05, 2012 | Vtech DECT 6.0 Digital Cordless Phone
My answering machine (phone line) is picking up when I dial my fax number. How do I set my fax machine up so that it will pick up when I dial the fax number?
Either your fax machine is set to answer on more rings then your answering machine is or you dont have the automatic answer key pushed?
Determine how many rings your answering machine picks up on and then change the number of rings to a lower amount on your fax machine. To change the number of rings before picking up the line, press the "menu" key on the fax machine and use the up and down arrows to scroll until you find the "basic fax set up" or the "advanced set up" areas. I am not sure which one will have the number of rings setting. Try looking in both until you find it.
when you see it press "ok" or "enter" get in and change the amount of rings before answering. call your fax machine to make sure it picks up before your answering machine.
This should solve your problem.
Mar 21, 2011 | Office Equipment & Supplies
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
Mar 24, 2010 | GE 29870GE1 Corded Phone
Increase the number of rings
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
BellSouth Digital Answering System 2006C Digital Answering Machine Logo
Top BellSouth Lands Phones Experts
Tom Chichester
Are you a BellSouth Lands Phone Expert? Answer questions, earn points and help others
