Question about Car Audio & Video
Mb quart qm 130 tc - Car Audio & Video
How do you turn the temperature up and down on a steamist tc 130 thermostat?
Google (steamist)(tc 130)(manual) without parens to get instructions.
Nov 13, 2016 | Heating & Cooling
MB QUART WIRED REMOTE WRC-S1 NOT WORKING
test the LED hit any key viewing with digital or cell digital. see the diagram THE LED must be TURN ON, if not open the remote and clean the keypads contacts from dirty+corrosion+bad contacts+clean the contacts battery too and replace by new ones.Try it again.
God bless you
Jul 14, 2013 | MB Quart WRC-S1 Round Wired Remote Control
Mb quart marine stereo fuse issues WR 1-CD
There might be some shorted component/s on the circuit board. Seek tech support.
Jun 02, 2012 | MB Quart ALX80IW Main / Stereo Speaker
What type of oil to use for iol change and how many quarts?
I use Castrol 20W50 motorcycle oil in mine. Supposed to use 20W40 but try to find that at any place other than a Victory shop. Any good brand name 20W50 motorcycle oil will work fine and you will need 6 quarts--------------yes--------6 quarts!!!!
Oct 13, 2010 | 2002 Victory V 92 TC Deluxe
What is the impedance and do they need a capactor on or is crossover built in?
Product MPN MPN RTC 19 Key Features Car Speaker Type dtrquestion.gif Component Car Speaker Function dtrquestion.gif Tweeter Size 1" Nominal Power Handling dtrquestion.gif 70 Watt RMS Technical Features Peak Power Handling 130 Watt Frequency Response 2500 Hz - 32 kHz Sensitivity 87 dB Impedance 4 ohm (Dual Coil)
please be advised you need the crossover that came with it, or you will need an active crossover dedicated to an amplifier to run these.
Aug 14, 2010 | MB Quart RTC 19 Car Tweeter
What are the specs,rms ect on my older mb quart psc 216 speakers
Any type of 4 channel amp that will allow the speakers to be hooked up at 4ohm. I would check your local walmart. The brand VR3 are made by Rockford fosgate as well as lighting audio. From what I have heard they are some really good amps at affordable prices. If you are looking to spend some money I would recommend a JL Audio e2150
Oct 28, 2009 | MB Quart Car Audio & Video
How many quarts of transmission fluid does a 1995 chrysler concorde hold
That depends if you are talking about dropping the pan only - or fluid for the entire trani including the tourque converter..
If only dropping the pan - it should be about 3 to 5 quarts..
It its for the hole trani & tc - it should be 6 to 9 quarts..
Rate me good ;o)
Jul 09, 2009 | 1995 Chrysler Concorde
Tweeters fading out
Turn on the HPF it will definatly clear up the sound.
Aug 07, 2006 | MB Quart DSD 216 Car Component System
Car Audio & Video Logo
65 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
