Question about Electrolux 30" Self-Cleaning Freestanding Electric Convection Range - White
Front right element popped and started a fire...I replaced the element with a new one...I turned on the burner and nothing happens...is there a fuse for each burner? The other 3 burners are working properly...I can see no physical damage to the receptacle. Help please!
    President:
  • 272 Answers
Usually when a burner goes it is the switch that goes at the same time. There is a fusable link in the switch itself that blows, they are easy to replace. It is usually best to replace the recerptacle as well as the surge usually builds up a lot of carbon on the connectors and may cause some arcing and difficulty down the road.
Posted on May 18, 2009
  • darlenedaley
    darlenedaley Oct 31, 2012
    Where is the switch located? I took the back off the stove and all looks good there.
Using oven and there was a pop and it went dead...oven, stovetop burner, clock panel, oven light!
Your element has burnt out. Reset the breaker, and get a new element. You can usually see where it has gone.
Some older stoves have glass fuses hidden behind the front panel.
Apr 16, 2016 | Kitchen Ranges
When I turn on my oven it does not stay at that temperature, went and bought a new heating element and that wasn't it, the oven heats up and the burners turn pure red like a broiler and don't regulate
sounds like you're having a problem with your thermocouple that's what regulates the temperature of the oven you can either try to clean it off or replace it
Jan 05, 2015 | Magic Chef Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Right front burner only works on "small element". Large element will not come on. Do i need a new burner?
Hi Will Lawler - If the small element turns on but the large element does not, then more than likely, the range has a faulty burner or switch. If I was in your position, I would personally contact a professional for an accurate diagnosis and to assist with the repairs.
Mar 10, 2013 | Frigidaire Gallery GLEFM397DS Electric...
The right front burner will not get hot. It is only warm never hot. The burner doesn't turn bright red even when tuned up on high.
hello, try changing that front element(burner)if its easily removable to another side that is working normal. If the element is still dull not heating or glowing normal then replace the element, but if it does, then there is something wrong with the front right element switch or the receptacle.
Oct 30, 2010 | KitchenAid Kitchen Ranges
The lower heating element broke in half, while I was waiting for the part we used the broil but the wires that attatch to the lower heating element touched the medel and their was a popping noise and now...
you may have blowen the fuse on one side of the power line . the burner's on top may still work . so replace the element that was bad and any wring that shorted and reset both fuses. so that 220 is present . and oven and top burners should be ok ..mm hope this helped . mm
Jul 11, 2010 | Ovens
Maytag Performa Electric dryer. Went to put in load and start-would not turn on. Checked breaker first. Then listed and I could hear the timer clickin on the front panel.Front door panel was full of lint....
In-laws machine did exactly the same thing. Check the thermal fuse.
Turn off the breaker.
Pop the top open with a flat screwdriver (there are two clips at the front)
There are two white wires on the right-side of the burner element, this is the thermal fuse (wires are kinda awkward to remove)
I jumpered these to wires and it started right up.
Jan 25, 2010 | Maytag PYE2300AY Electric Dryer
Infinite switch sparking!!!!
You have a short somewhere between the switch and the burner connector. Probably a wire's insulation has worn away or melted and is allowing the wire to contact the metal housing somewhere. You will see arc marks wherever the short is located. Look carefully where the wire passes through any holes or where sharp turns are encountered.
Aug 12, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Element burnt out
replace the swich for that burner.thats the one behind the knob.
Dec 02, 2008 | Hotpoint RB787 Electric Kitchen Range
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Electrolux 30" Self-Cleaning Freestanding Electric Convection Range - White Logo
165 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
