Question about Maytag Dryers
Dryer hums but will not start
Made s queling noise then won't start back up after last cycle complete. Unit is 8.5 years old.
  • Maytag Master
  • 2,699 Answers
Bad motor,if it does start and runs then shuts down and you can't restart it until it cools down you have a bad motor,or open the door and see if you can spin the drum,i found a dryer that the belt cut through the pastic belt pulley and the motor couldn't turn,also something could be stuck inthe blower wheel but if you can spin the drum then it's the motor.the noise you heard is either a bad roller,the belt pulley or the motor bearing.next time send the model number and i can look up you dryer to see what parts are in it.hope this helps.
Posted on Jan 19, 2014
dididsaythat
  • 291 Answers
SOURCE: Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Posted on Sep 17, 2007
Controlfrk
  • 304 Answers
SOURCE: My whirlpool dryer heat up. But does not spin.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
Belt and pulley configuration
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble.
Posted on Sep 07, 2009
heatman101
  • 43501 Answers
SOURCE: turn the On switch for the dryer it just makes a humming noise
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 15, 2010
heatman101
  • 43501 Answers
SOURCE: dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
Posted on Sep 29, 2010
heatman101
  • 43501 Answers
SOURCE: My LG DLE2514W electric dryer starting making a
heatman101
vciku
When I push the button to turn on its making a a humming noise and won't turn on. Its less than 2 years old
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Frigidaire Dryers
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Jul 14, 2011 | Frigidaire FEQ1442ES Electric Dryer
Our 8 year old kenmore dryer won't do anything when you press the start button. We don't hear even a hum. It worked one day and then just wouldn't start the next day. We checked the fuse box...
Here is a good link for basic troubleshooting... But 10 to one the culprit is a thermal fuse or thermal cut off.... they are usually pretty cheap and easy to replace....
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
One final note on these: if you find your thermal fuse\cut off (or element) open, before replacing it, be sure to check the airflow out your dryer's vent system. Even though these devices do 'wear out' with age, poor airflow's the #1 cause of failure of these devices, and if your vent's partially clogged, a new thermal won't last very long, but will do its job again, and leave you 'cold' (a new element won't last long if the vent's clogged, either).
More info and pics:
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Jun 16, 2011 | Kenmore Dryers
Humming Noise When Start Button Pressed
Dryer Repair ? The dryer will not start
heatman101
May 10, 2010 | Dryers
A dryer2_bing.gif may not start for many reasons...
heatman101
Apr 26, 2010 | Dryers
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
The dryer is 8 years old. When I push in the dial
the motor is not turning and that's what is humming,you either have a bad motor,something stuck in the blower usually a sock or the belt is stuck
Nov 02, 2009 | Amana DLE330RAW Electric Dryer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Mar 24, 2009 | Bosch Dishwashers
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Dryers Logo
56 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
