Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Picture problem My Philips 60pp9202-17f was working fine 24 hours ago. Today when I turned it on, the picture has green outline on the bottom. The picture appears to bow slightly inward on the bottom and top. I have tried to adjust each convergance manually with no success.
  • 4 more comments
  • wwknight2 Dec 28, 2007
    I seem to have the same problem. I also need a remote.
  • Anonymous Dec 29, 2007
    kkk
  • misha1223 Dec 29, 2007
    I have the same problem, the tv was working fine in the morning, when I turned it back on 3 hrs. later, the dish guide looked like it was written in red/green letters, turned on the show and all the people had red and green shadows (outlines) around them. We bought the set used from someone and they did not have the remote, can't seem to adjust the convergence without the remote. Any suggestions???
  • frogette Jan 02, 2008
    Same problem. My TV is over 5 years old. It is cheaper to just buy a new TV (smaller of course) or to fix it. Sure love my big screen though :( I have tried to adjust the colors manually, but it won't work. Don't have a remote, but was able to access the menu off the TV directly.
  • Anonymous Jan 04, 2008
    Hello! I have the same issue. I going to replace couple IC's how it was advise below. Can anyone tell me is it any difference between STK392-110 and STK392-120. I have Philips 60PP9202 60 in.
  • Rich74560 Sep 03, 2008
    I own a Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television. The screen is curved on the top and bottom, also the display numbers and letters are shadowed by red and green numbers. What steps do i take to try and fix tv before i call a repair man.
    Genius:
  • 1,694 Answers
Convergence overhaul needed =====
1)Pull chassis
2)Replace Stk392-110 IC's x 2
3)reset alignment
  Usually a 400.00 repair at a tv shop......T.
Posted on Oct 25, 2007
  • John Peace
    John Peace Aug 12, 2012
    i have another tv the same but smaller it works i switched out the board on left rear the same as tv with bow but no change i think the part on right is the problem held in with 2 screws and grove slot on bottom can i just take that in and have it fixed and save$$$$
I have a Panasonic pt-61lcx65 and everything works fine but in the picture there a outline of green and shades of green on the picture, and I've tried everything to get to the service mode to adjust the...
I own the same set in the 44" version. These often need a "prom flash" with the panasonic programming jig to correct for color spots" in the picture. Mine did, over 3 years ago and has bee ok since.
Apr 30, 2014 | Televison & Video
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site www.TvRepairKits.com
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
I have sound but no picture, over the last month it has been taking an hour to get sound and picture from switch on, but today it is just sound after about 2 hours. 15PF4121/05
Similar problem in my Philips. No picture, just green led flashing in front panel. Reason was dried up capacitors in power supply card. Came on by renewing c223 and c228.
Jan 18, 2010 | Philips 15PF4121 15 in. LCD Television
Projection lights don't line up
Sounds like your convergence chips have failed. This is a common problem. You can get a repair kit from www.TvRepairKits.com .
Apr 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture problem
I have the exact same problem a month ago. I replaced the two STK392-110 ICs with the STK392-110T adn everything went back to the way it was.
Jul 01, 2008 | Toshiba TZ50V61 50" Rear Projection...
Convergence / Short? 60PP9401
First thing to know = your set is Hitachi made with Philips
name on it....not a bad thing, just good to know.....
Parts to change out = STK392-110 IC's sub to upgrade
STK394-160E part # CZ 01341 , change both for reliability...
Then activate Intellisense and see if all is well........T.
Dec 14, 2007 | Philips 60PP9401 60" Rear Projection...
Picture has turned green
Possible green CRT bad....remove lower front speaker cover
and access panel.......carefully disconnect green PC board
from green CRT ( center tube )....plug in TV..power set....should have steady red/blue pix (no green) = bad green CRT............T.
Oct 27, 2007 | Toshiba TZ55V61 55" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
197 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
