Question about Poulan "Poulan" Pp325 17" Gas Brushcutter Trimmer
How to remove clutch on Poulan Pro PPB350 gas trimmer
I have a Poulan pro PPB350 gas trimmer I need to replace ignition module but I can not get the clutch off how do I do this
  • jpg19571 May 19, 2009
    Thanks Longhorn ordered one from ebay for $8.00 bucks shipped
  • Anonymous May 24, 2009
    How to remove clutch on Poulan Pro PPB250 gas Trimmer so the Starter cord can be replaced...
  • 376 Answers
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool... That should work for you. Dwainhow to remove clutch on Poulan Pro PPB350 gas trim - b076e56.jpg
Posted on May 19, 2009
Troubleshooting no spark
Most times it is the ignition module does not have a good ground where it mounts. If the ignition has good ground, disconnect the kill wire and see if you get spark. If yes, replace the kill switch.
Aug 04, 2014 | Poulan Pro 25hht 25cc 22" Gas Hedge...
Poulan trimmer drive shaft attachment problem
Square drive on the end of the drive shaft has to line up with the drive on the output of the clutch.
Jul 07, 2014 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Poulan pro ppb350 weed trimmer stalls when choke is open
-After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
Because the engine need more air to burn the gas.
Good Luck
mai
Jun 06, 2014 | Garden
I have a Poulan Pro string trimmer model PPB350. It was purchased in 2005, but hasn't been used more than 12 t0 15 times. It has always been hard to start, but once it was started it ran fine. I have...
The next thing I would change would be the in tank fuel filter. It can be pulled out with a hook on a wire. Most any lawn repair shop will have them.
Aug 07, 2017 | Poulan Garden
My poulan pro trimmer has no nut on the head to remove it. it has a screw inside. how do i work that. the screwdriver wont hold it.
See page 13 of your manual here for removing the head. Please realize that the head has LEFT_HANDED threads on it (not the conventional R-handed) so you have to turn it to the RIGHT to loosen and remove it.
http://dl.owneriq.net/0/025d5114-7fc1-41e0-8faa-5205f15e8cf5.pdf
Aug 07, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Fuel mixture for poulan pro heavy duty brushcutter 331 sn 01254n500330-1is needed asap. lost my manual!!!!!
40:1 mix, 3.2 oz of 2 stroke oil for every gallon of gas.
Link to the manual is below
http://www.poulanpro.com/ddoc/POUO/POUO2001_USen/POUO2001_USen__530088910.pdf
May 27, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
I have (had) the Poulan Pro 25 cc trimmer. The motor and main shaft have been nothing but problems for me. I still have the attachments. Do you know if there is a way just to buy the main shaft/motor? ...
Sure you can...that would be called the crankshaft assembly. You can find it here...along with any other parts you may wish/need. These low-end trimmers are practically considered disposable household items nowadays and a lot of people treat them as such. Look for the crankshaft assembly here:
http://www.ereplacementparts.com/poulan-pro-pp125-gas-trimmer-parts-c-16962_17820_18351.html
I am a little surprised at the lower cost.
Sep 14, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to remove the clutch from a poulan prolink
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool.... b61de2e.jpg
Jun 09, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan "Poulan" Pp325 17" Gas Brushcutter Trimmer Logo
1,082 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
