Question about American Standard 2083.102 Standard Collection Bathtub, Right hand outlet
NEW American Standard shower installed... leaks from shower head.
I have replaced the 'cartrage' and pressure balancing unit several times... still slowly dripping! They say that it must be a faulty cartrage... but after three trys it seems that they eithe all leak or something else is going on.
  • 1 more comment
  • Anonymous May 19, 2009
    It is a new install (never used)... I will try the grease idea. Thanks
  • karl p Jan 03, 2013
    I am having the same issue....Am Standard said the units are pressure tested at 100psi I am only running 60. Does anyone have a suggestion?
  • Anonymous Mar 29, 2014
    shower head drips when shut off
  • 10,865 Answers
They do not all leak. The problem may be that your faucet is simply wearing out and is due to be replaced in total. Try putting some plumbers grease on the cartridge and the chamber.....not too much..........that may do the trick for u.
Posted on May 19, 2009
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
What's wrong with a leaking shower head following new boiler and how do I fix it?
The valves are leaking. It's not the shower head itself. Sometimes shower faucets require special tools to service the valves. If you have thought about new shower valves, now would be a good time to replace. Repair may be half the cost of installation of new. In other words, plumber's time to repair or replace is about the same. Get several quotes. TV show This Old House had one on a replacement. It may be available online. Home Depot or Lowes or Ace Hardware may be able to help, Or similar Hardware outlet in your area.
Feb 13, 2015 | Water Heaters
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
The shower does not get hot so i took pressure balance unit apart and cleaned also took hot limit stop off .still not hot rest of sinks in house are hot and furnace right under shower,what do you think it...
When shower faucet apart make sure hot is getting 2 & coming out faucet ***. did you turn off stop integral w/ faucet or outgoing shut off valve on water heater.. May have rust or lime in small orifice leading to faucet ***. does your balancer/ piston move freely..good luck..
Mar 24, 2011 | American Standard Bath Faucet Ceramix...
Water will not flow through on american standard with pressure balance. Some hot water came out with low pressure then stopped and now nothing will flow.
I just spent a week wrestling with a similar problem, and I'm posting in an attempt to save someone else an ulcer. Using a Colony single-handle valve, the temperature got so we couldn't control it. Either all hot or all cold. I called A.S. and they sent a new pressure balancing cartridge and new valve cartridge. Replaced both and then there was no water at all coming out of the shower head. Tried every possible combination of old and new parts, flushed pipes, etc. Finally took the shower head off and found it completely clogged with debris. It was a mix of sediment and the white grease that was in the new cartridges, which must have been displaced when I started messing with it. And it clogged it all at once (no flow problems before all of this). Works fine now!
Jan 02, 2011 | American Standard One Handle Shower Only...
How do you remove the cartridge from an american
Turn off the water to the shower.
Remove the handle cover (it should pop off)
Remove the center screw (usually phillips head)
Remove the retaining clip holding cartridge in - you can use a pair of long nose piers or a small screwdriver
Grab the cartridge with a pair of pliers and pull straight out. It may require a little force - there are O-rings around the cartridge to keep it from leaking.
Check the cartridge bore (the hole where the cartridge was removed)
Clean any debris or scale - lime away or CLR will work
Apply a little bit of soap around the new cartridge to help it slide in easier. Push it all the way in and make sure it is seated. Re-install the clip (you should have received a new clip with the replacement cartridge)
Turn the water back on a check for leaks
If OK, reinstall the knob screw, and cap.
Dec 12, 2009 | American Standard Williamsburg Satin...
Leaking shower faucet
You may want to disassymble the faucet again and check for any debris that could have gotten into the faucet when you were changing the cartridge. Also remove the seats at the back of the housing and reexamine for bad seals. Sometimes it takes a second install for it to stop. Something isn't seating properly plus, it could be a bad new cartridge.
Apr 07, 2009 | Plumbing
Single knob for shower and tub wont stop running
You may have debris caught in the cartridge. I'm not sure which faucet you have but if it utilizes a ball, there is a retaining ring that is either grey or white that you have to tighten. If not, I would recommend contacting American Standard. You might have a bad cartridge or missed replacing another part. Sometimes they have small round washers at the back of the housing that need to be replaced as well.
Apr 01, 2009 | American Standard T375248.002 Polished...
I have installed an AS 2555.501 Pressure Balance Vave and now the water pressure in the shower is low
this problem happens quite regularly as the valve will reduce the pressure but sometimes it will reduce too much, you can adjust it up, but you havent mentioned which type of shower valve it serves?
as the shower may not be suitable for the plumbing supplies it connects too , & how they are installed?
i am thinking its from the cold water main & that the valve requires storage feed instead of incoming water main supply? possibly thats why you installed a reducing valve??
Let me know?
Kindly
Richie
Dec 15, 2008 | American Standard 2555.501.295 Satin Town...
American Standard 2083.102 Standard Collection Bathtub, Right hand outlet Logo
491 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
