Question about Cell Phones
Hitachi tv just brought a 24HXJ15U and I dont know how to get on too the internet with it
I have a Hitachi 42 inch smart TV and I want to know what to do if the internet menu is not loading
There are as many possibilities as there are when trying to find a needle in the haystack. The first think to look for is the WiFi is in range. How o you do the Internet on TV, cable, Wireless or... I don't know unless you spend little more time next time you write a problem on FixYa. You first need to explain whether it is cable connection to the TV, which is a bit impossible, unless your smart TV has wireless connections. Other things that you need to check is the wireless range seen on the TV (those tiny bar-graphs usually seen at the bottom right of the screen), are they all active? They're usually 5 little vertical bars. If the Wireless is fine, you can be sure you will have the Internet, no matter what. If it is not loading you have to reset the code to match the wireless signal of your ISP. Better still, your TV is really a modern one, since it is a Smart TV and it comes with a Manual you cannot fail to understand. Read it carefully under the 'Wireless Connection' section and you cannot go wrong. Panicking over nothing doesn't get you anywhere closer to a solution to your problem. Like computers, Smart TV requires an Internet Service Provider (ISP) and a Wireless Modem to start with. Do you still feel confused? Then try this link below. It may help you... http://www.knowhow.com/article.dhtml?articleReference=1246&country=uk ...or, lastly, contact Hitachi.
Jul 06, 2014 | Televison & Video
I cant connect my WiFi router to my Hitachi smart TV
How do I actually delete the numbers in my DNS server
Dec 26, 2013 | Computers & Internet
Hi this is sekhar i purchased one hitachi hard disk, present it is failure it have warranty up to 2011. any one know hitachi harddisk service center in hyderabd or secundarabad........plz call me or...
Why dont you try to replace it where you brought it from just visit ctc in secunderabad and try to ask there it is a big computer bazar where u get everything
Aug 20, 2010 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Dont know how to get the stations tuned in on Hitachi Stereo
best bet is go to there internet site and then support download the manual
Mar 12, 2010 | Audio Players & Recorders
Picture messed up
you would need a digital board try to check this web page www.discount-merchant.com
Dec 18, 2009 | Hitachi 46GX01B 46" Rear Projection...
I brought a use psp 1001, dont know the security code
try this but it might take all day start from 0000 and end at 9999 try all the combinitaions in the middle it might take the whole day and/or go back where u bought it and ask them or trade it in for a new one
Oct 28, 2009 | Sony PlayStation Portable (PSP) Console
55HT79 HITACHI BLUE POWER LIGHT BLINKS ON AND OFF.
I can't help you because after 26 months of ownership mine is doing the same thing (started on 7-12-09). Judging by the number of people with the same complaint I believe Hitachi knows that they have bad boards but refuses to replace them for customers unless they are within warranty. It also explains why the merchant that sold it to me in 2007 stopped offering Hitachi in 2008.
I'm disgusted because I'm anticipating a $300-$500 repair bill simply because Hitachi's design did not provide an external way of resetting it. Impossible to get to the menu to do a reset within 12 seconds before it starts the powering on booting cycle again.
Adding salt to the injury, mine is wall mounted and repair people will only work on it if it is readily accessilble when they walk in the door or if it is brought to the shop. Know what a 55" plasma TV weighs? Too much.
Jul 09, 2009 | Hitachi 55HDT79 55 in. Plasma HDTV
Problem with used TV
It depends on whats wrong. It may just be a loose cable. Most shops will charge 300 - 400 for the average repair.
Jun 25, 2009 | Hitachi 50UX57B 50" Rear Projection...
Vertical Green Bar 3" wide on the right side of my 42" plasma
My thought is that it is an Intergrated Circuit (IC). But it has been brought to my attention that it may be as simple as adding a "ground adapter" to the plug of the TV. If after you try changing out the ground adapter and it doesn't work, try "power cycling" your TV. (unpluging it... Waiting 30 seconds, then plug it back in.) If that fails, contact Hitachi so they can recommend an authorized service center in your area. Hope this helps. Good luck, KMarshall!
May 25, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
