Question about Guess Dress Gents Bracelet W11562G3 WW Watch for Men
Lost manual How do i adjust the day of the month
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 09, 2010 | Watches
I lost my manual for setting time on a White Deuce Watch. Where can I find instructions
You will need something with a fine point, like a pen. Turn the watch inside out and you will see two small buttons that are used to adjust the time. Place the tip of the pen on the top button and press it 4 times - or until you see the P or A pop up (PM or AM) or time (hour or minute) or date (day or month) flash. Then use the tip of the pen for the bottom button and press it until you get the correct hour of the day. Hit the top button again to get to the minutes. Press the bottom button until you get the correct minute of the day. Press the top button again until you get back to deuce blinking on the watch and you are done.
Dec 24, 2010 | Guess Watches
Hi there, I got the Citizen Projection Clock DX8200-B as a birthday present from a dear friend. At one point of time, I misplaced the manual. I do not know how to adjust the the time and the date on the...
I have the same clock and i went back to the shop to help me adjust the time today. I lost my manual and could not figure out how to adjust the time. First, push MODE until it displays the temperature. It will not work if the alarm time is being displayed. Then, hold MODE for a few seconds and the year, month, day will start to flash in sequence if you push MODE again. Push MODE again until the time starts to flash and there, you can adjust the time with + or -. Good Luck!
Nov 02, 2010 | Watches
How do i adjust the date on my classic watch?? pull the pin and rotate cw or ccw no changes.i have an indigo classic watch. does date need to be adjusted every 30 day months? thanks
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Jan 12, 2010 | Timex 5B841 Wristwatch
Lost my instruction manual
need to set day,because it's shows from the day before, date is ok...thanks
Jul 02, 2009 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Need instructions for Timex 1440 Sport watch
TIME AND DATE
CHRONOGRAPH
4. Press ADJUST to view lap time. Press again to sesume lap timing.
Nov 22, 2008 | Timex 1440 Nylon watch
Adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Sep 05, 2008 | Festina 161625 Wrist Watch
Anne Klein chronograph watch
The button advances the numeric day. After the numeric day is advanced one full month, the month dial advances to the next month. I just about got a blister pressing the button enough times to advance the month from January all the way around to December. Then I had to advance the numeric day to the current numeric day. The previous person told you by turning the dial 24 hours you can advance the alphabetic day of the week by one day (Sun, Mon,etc.).
Sep 04, 2008 | Casio G-Shock G7100D-1V Wrist Watch
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Guess Dress Gents Bracelet W11562G3 WW Watch for Men Logo
14 people viewed this question
Top Guess Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Guess Watch Expert? Answer questions, earn points and help others
