Question about Watches
Tissot Veloci-T Automatic Watch T024.427.27.011.00 owner manual
  • 73 Answers
SOURCE: tissot watch prs 516 automatic
I would recommend going to the following link and follow the instructions for resetting the counters and see if that corrects the issue.
http://www.tissot.ch/data/usersmanual/134-en.pdf
Posted on Feb 21, 2008
SOURCE: tissot navigator manual
DIRECT LINK
http://www.t-touch.com/t-touch_images/usersmanual/140-en.pdf
Posted on May 20, 2008
escapement
  • 2334 Answers
SOURCE: Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 04, 2009
escapement
  • 2334 Answers
SOURCE: tissot wristwatch model PR 516 GL
I guess you never overhauled your watch.Every mechanism has it's limits - so does the watch movements. Your watch has ETA Swiss made mechanical movement which is very good and reliable, but you have to take care of it from time to time. Mechanical movements are designed to last almost forever if they are looked after and yours isn't an exception. Bring it down to the local watchmaker and ask to overhaul it. It will run as new again and will not let you down. It is recommended to overhaul mechanical watches every 4-6 years. If this will be done, your watch will happily tick-tock on your grand-grand-grand-grand-grand-grand children's wrist and they will remember you with a few good words and respect.
Posted on Jan 08, 2010
  • 2501 Answers
SOURCE: Synchronize analog and digital time on Tissot T33 T-Touch Watch
I could not get any result from entering your model in their web site but the "T Touch online" seems to be a watch that has similar features perhaps.
Their catalogues seem to be generic, so by going to their web site http://support.tissot.ch/?mod_flashPDF/id_138 you may finswhat you need.
Posted on Apr 17, 2010
The tissot visodate watch is automatic not battery driven.
I would not wind the watch manually. I also have a Tissot. If you cannot wear it often enough to keep it going, you can purchase a watch box that is made for self-winding watches which will turn the watch periodically in order to keep it wound.
Oct 19, 2012 | Tissot Visodate Automatic Leather Mens...
Can you upload instruction manual for tissot txl t60.1.588.51 watch
Welcome to Fixya. You can try to find the manual on the link below just make sure you select or provide the reference number or the watch family
Tissot Support
Thanks
Jul 27, 2011 | Tissot TXL T60.1.588.51 Wrist Watch
Hello, I have a Tissot Veloci-T watch, purchased about 10 days ago, and I'm not sure if there is a mechanical problem or just merely a battery issue. The hour and minute hands do not sync up on...
The list of problems is impressive and if you still have the proof of purchase, it should go back to Tissot for repair or replacement. It shouldn't matter where you bought it, so long as you can prove that it is within the warranty period.
(It sounds as though it has been dropped onto a hard surface)
If you haven't got any proof of purchase, then you will have to pay for any repairs.
May 08, 2011 | Tissot T0244171705100 Velocit Watch for...
I was given a Tissot Seastar and I know nothing about it or if it's worth fixing. It has a 17 jewel automatic movement which works fine.It also has the day and date. The movement number is 14190996 and the...
If it is the eta 2824-2 model. When you say the hands don't turn, I take it it does not work? its an automatic so needs wrist/ hand movement to wind the rotor. You can manually wind the watch by simply turning the crown (without pulling the crown out) Try doing this first.
Apr 30, 2017 | Tissot Watches
Tissot T33.1.588.51 T-Touch Black Dial?
If the functions dont work from moisture I can repair it.
if the sensor damaged the watch is unrepairable and only the swatch group service center can repair this watch.please check my Blog i have many posts about these problems for all Tissot T Touch Series
Watchmaker Video Review For Watchmakers and Watch Fans
Sep 08, 2008 | Tissot T33.1.588.51 T-Touch Dial
Tissot watch prs 516 automatic
Jun 19, 2007 | Tissot PRS 516 T91142651 Wrist Watch
Watches Logo
16 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
