Question about Sanyo CLT1554 15 in. EDTV-Ready LCD Television
Tv takes too long to warm up - Sanyo CLT1554 15 in. EDTV-Ready LCD Television
Sharp LCD TV Takes Too Long to Turn On
Your TV main board is failing, soon it will not turn on at all, plan on buying a new one soon.
Aug 12, 2016 | Sharp Televison & Video
Tv takes ages to warm up
this sounds like bad capacitors on power supply board well worth replacing now rather than later
May 26, 2014 | iLO 3200 32 in. LCD Television
Partial picture frozen
Hi Robert
Possibly bad video memory.
LSI Chip failure until warms up.
Feb 24, 2014 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
I have a Toshiba 36"
Resolders the FBT-(flyback tranformer).Resolders the video board connections sockets holes,that the board connected to the CRT-(tv tube).Plug in the tv,to have power to the tv,take out the tv video board,for exposer of the CRT-(tv tube).Take an electrical wire with a good insalation in it,grounded to the tv steel frame some where.Take the other end of the wire go toward the open high voltage CRT-(tv tube).U will hear a pop sound,than ur tv CRT-(tv tube) is a 100% clean out of contaminations or u will hear a deeing sounds only,mean the tv CRT-(tv tube) it is to old to pop anymore,just let tv deeing sounds going on for like about 20 mins to rejuvenated the old CRT-(tv tube).After this repluging the tv video board for a tv signal and readjust the button on the FBT-(flyback tranformer) that said focus to fix the CRT-(tv tube) focus problems.
May 01, 2011 | Toshiba 36A40 36" TV
TV Flickering, Wave, and Warming Up Problem
The capicators in the hyperboard have failed. An esy fix if your patient. Otherwise I offer a repair service. Let me know.
Feb 03, 2010 | Toshiba 50H81 50" Rear Projection...
Takes five for the tv to warm up and produce a
you have a bad capacitor in the power board , the board is the one where the AC cord plugs or leads to .. the can shape eletroletic will be domed or puffed up at the top where it has vented the value is printed on the side you can or have it replaced by a tech parts under a buck
Dec 11, 2009 | Samsung PN58B650 TV
Magnavox 52" widescreen 2003... When you turn it on it takes abou
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up.
After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Jan 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Tuning in takes ages whilst warms up
IF your TV is not one of the real old ones, you have a problem with the automatic tuning system. Some component in this circuit most likely a capacitor or coil is changing its electrical properties due to temperature which in turn causes the set to be off frequency until it warms up. A capacitor (condenser) can do this quite often. Stargazer
Jan 10, 2007 | Bush 2871NTX 28" TV
Sanyo CLT1554 15 in. EDTV-Ready LCD Television Logo
13 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
