Question about HP Office Equipment & Supplies
My hp 470 ink wastepad is full, how do I fix - HP Office Equipment & Supplies
  • 68 Answers
Open the cover of the printer.The wastepad was screwed.
Unscrew it then remove the wastepad then replace a new one.Clean also the wiper for additional maintenance.its located below the carrier.
Posted on May 19, 2009
HOW INK PAD L200
download an adjustment program and reset your wastepad ink counter. hope to be of help
Jun 17, 2014 | Epson Stylus Multifunction Inkjet Printer/...
Where is the actual waste ink tank located in HP 470 office jet mobile printer?
where is the waste ink tank in the hp photosmart c4280 all in one printer
Sep 11, 2013 | Canon MultiPASS F80 All-In-One InkJet...
Hp 470 printer prints blank pages after replacing ink cart and reinstalling drivers and can't get the wireless feature to work
--Try to remove the cartridges
--closing the door
--unplug the printer
--plug the printer in
--when the printer powers on it will acknowledge the missing cartridges
--then put in the carts
See if the alignment page prints out with colour.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 24, 2013 | Office Equipment & Supplies
Error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
E07, e08, e02, e15 error in canon mp258, pl. give meaning of error & solution
Canon Pixma Mp258 Error Code and Possible Solution
P02 (Carriage error)
1.Make sure no foreign material stuck to the print head railway.
2.Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.P03 (Line feed error): an error in transmission line entering the line feed (LF) is a signal telling the printer to move to another line or a whole new line that would not otherwise have reached the end of the line.
1.Check wire print head position (timing **** disk film) on the side of the machine.
2.Check PCB logic board.
P05 (ASF sensor error) sensor for paper feed error.
1.Try to replace the following:
•ASF / PE sensor unit.
•Drive unit.
•PCB logic board.
P06 (Internal temperature error): caused by abnormal heat inside the printer.
P07 (Ink absorber full): the Ink Wastepad (sponge) inside the printer is full
1.Replace the wastepad inside the printer or install waste ink bin outside the printer
2.then Reset counter protection.
P08 (Print head temperature rise error): caused by thermal print head temperature exceeds a threshold.
1.Replace the new cartridge print head and / or change a new logic board.
P09 (EEPROM error): caused by corrupted or defective EEPROM chips of the printer.
1.Replace the logic board.
P15 (USB VBUS over current): caused by too much current, try removing the USB cable and then plugin again, if solve the error, try to replace with a new USB cable. If the error still exist replace the logic board.
P20 (Other hardware error): The failure of other hardware.
1.Try to replace the logic board.
P22 (Scanner error): a scanner malfunction.
1.try to change the scanner unit or change a the logic board.
E13 or E16: Ink has run out
1.Pressing the Stop / Reset button for 5 to 8 seconds until the led screen display number 1.
E04, E05, E14 or E15: Cartridge may not be installed properly
1.Reinstall the ink cartridge.
Jun 15, 2011 | Office Equipment & Supplies
I am receiving a message that the ink absorber is getting full on my Canon Pixma MP160. Is this something I can change out or do you recommend that it be done by the pros? I was unable to find any...
your ink wastepad is almost full. You need to replace the ink wastepad inside the printer or install a wastebin then reset the printer counter protection. If you know how to change wastepad then try these the instruction on how to reset your printer.
http://pcmediks.blogspot.com/2010/11/how-to-reset-canon-mp150-mp160-mp170.html
but if you dont know how to replace the ink wastepad inside the printer better to call someone who can.
Dec 18, 2010 | Office Equipment & Supplies
I just changed the ink cartridges in my HP F4280 printer, and now documents are printing blurry, with horizontal alternating dark and light lines, as well as some smudging along the left margin. What can I...
Hi! You may want to try head cleaning to resolve the blurry prints. The smudge may be caused by a full waste ink pad. Try to replace the wastepad and it may resolve the problem. Hope this helps and have a good one!
Jun 05, 2010 | HP DeskJet F4280 All In One Printer InkJet
Spillbläck full? What to do
It means that the pad that absorbs the ink when the heads are cleaned is full and if you use it more it will spill the ink over your desk. The official way to deal with that is to take the printer to a dealer and they will clean the absorbing pad and reset the warning.
You can do both yourself:
1 - to clean the ink pad: remove the cartridges and unplug the combo - the carousel should remain in the middle, leaving the pad in the right side visible; take the printer to your sink and pour water over it thru a pipe (try not to splash it everywhere) until the pad becomes white and the water that flows out colourless; allow it to dry thoroughly (at least 2 days in a hot environment).
2 - Reset the Waste Ink Volume Counter
1) Press Menu + Copy + # to enter SERVICE MODE.
2) Select TEST MODE.
3) Select 8 - PRINTER TEST in TEST MODE.
4) Select 3 - EEPROM CLEAR.
5) Select 0 - INK COUNT.
6) Press the OK key.
7) Press the Stop/Reset key (returning to the state of 3) and then press the ON/OFF key.
May 01, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Canon Pixma 470/ cyan and yellow won't print
it may be many things, here some thing to try:
the ink or toner is contrammed with foreign liqued like oils, water, bad ink, bad toner cartridge,
oil, water, ink toner inside the ink itself
oil from a human skin my have came in contact with refill of ink or toner cartridge, cleaning solvent to clean the cartridge, needles for hte ink or toner cartridge, water in the ink or toner cartridge, steam or vapors of some kind, compress air can or air compressor will spread water solution, the freon is used in compressed air can thats way they get so cold when you spray the can.
paper may also be wet some how try new and different brand of paper.
rod the candymangandy
Feb 04, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
255 people viewed this question
Seeker5211
Seeker5211
