Question about Craftsman Garden
Craftsman chainsaw will not keep running
Needs fuel adjustments
    Problem Solver:
  • 7 Answers
Most saws will have a high, low and idle screw adjustments.
First make sure we are dealing with a clean air filter, clean with air or tap air filter and brush to remove saw dust. Replace fuel if it is a season old or older. (Fuel filter replacement if it has seen years of use.)
2nd GENTLY turn the high screw clock wise until it bottoms out and then counter clock wise 1 and a quarter turns.
3rd do the same for the low idle.
It should run and idle at this point, let it warm up before making final adjustments. If it dies when giving it gas then more than likely it will need further adjustment on the low idle screw.
If it is really stubborn, often times the the ports are full of sludge from the bad fuel. I prefer to remove the bar and chain especially for the novice. Start the saw, secure with another set of hands if need be, turn the idle screw in to quicken the speed a little. Now you can work the low and high screws back and forth 1/4 turn while the saw is running, periodically giving it full throttle. That should be enough to dislodge buildup replace bar and chain and then your final adjustment.
If not you may have to look else where as in an air leak.
Good luck and be careful!
jeromekj
Posted on Apr 22, 2014
stug_57u
  • 99 Answers
SOURCE: chainsaw won't keep running except on full throttle?
Running at full throttle but not at idle would probably be caused by not enough air getting through to the cylinder with the fuel. This could be caused by blocked/dirty air filter, air leak or worn/damaged piston or cylinder. The higher the revs are the less air to fuel ratio is needed so it will run at these speeds. First check your air filter, if that is fine take the spark plug out and examine the inside of the cylinder. You will need to check here with the piston down. If you want to be a bit more thorough you can remove the exhaust and check the piston face and inside the cylinder from here aswell. You don't want to see any scoring or solid lumps of anything in here. While you have the exhaust off give it a few firm taps to make sure there is no major carbon build up and clean the spark arrestor if it has one. The arrestor is normally a small gause found on or near the exaust outlet pipe. If that all seems fine then get some soapy water and squirt it around the carb gaskets and pipe that runs from the carb to the cylinder. If you see bubbles appearing here when the machine is running then you have air escaping and it will need investigating. Failing this you could have worn piston rings or crank seals. Ideally to test this area you need proper pressure testing equipment.
Posted on Oct 27, 2008
  • 16 Answers
SOURCE: craftsman 16'' chainsaw, start with very high rpm, how to adjust ?
The H is for when your cutting,it keeps the saw from stalling. The L, is for the saw when at Idle. When the L ,is adjusted right, the saw should stay running ,and the chain should not move ,that is with the break in the off position. The H screw,should be adjusted if the saw bogs down when rev ed up. A good starting point for theses screws would be a turn and one half out.
Posted on Jan 21, 2009
  • 376 Answers
SOURCE: I need the fuel mix ratio for a Craftsman 36cc
40:1
Posted on Jul 02, 2009
dontbother10
  • 2220 Answers
SOURCE: what fuel lines go where on a craftsman chainsaw
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Posted on Nov 02, 2009
Testimonial: "Hi Lou. I did have it backwards. I will change it to what you have and hope it works. Thanks, MIKE"
  • 71 Answers
SOURCE: Need replacment fuel lines and fuel filter for
Go to a chain saw dealer, you can buy line by the foot and get the filter.
Posted on Nov 28, 2010
Motor starts, move choke to run position motor runs rough
It could be time to carry out some routine maintenance.
The fault could be dirty fuel or dirt introduced by bad storing and filling practice. Small engines have very small fuel passages and it is important no dirt or moisture enters the fuel system so the fuel can, the spouts, funnels or whatever should be kept in pristine condition by being wrapped or covered in plastic sheeting between uses and it is good practice to never refuel in the rain or in a dusty environment.
I suggest you ensure the air filter and spark plug are in good order and then try to compensate for the fault by making a small adjustment to the fuel mixture by turning the high speed fuel screw a little while the engine is running at speed and at working temperature. Make a note of the current position of the screw slot so it can be returned to its original position if needed. The adjustment needed should be no more than half a turn in either direction but should be a great deal less. If it is more it is time to clean out the fuel system and carb.
Make adjustment of no more than 1/8th of a turn at a time until smooth running is restored. After high speed adjustment some further adjustment could be needed to the idle speed and low speed fuel screw.
Mar 15, 2015 | McLane Gas Edger-Trimmer 801-3-5RP-CA...
How to repair a flooding carburater
if the carburetor keeps flooding out, the float could be stuck in the up position. tap lightly on & around fuel reservoir to free. depending on age of carburetor, you might need to put in a carburetor kit.
Jan 23, 2015 | Cars & Trucks
Need tool for adjusting air fuel ratio for husqvarna 235 chain saw
It should be a spline tool. It is the most common one.
Genuine Poulan Weedeater Part 530035560 Carb Adjusting Tool
If you work a lot 2 cycle trimmers and chainsaws you might buying the set of four adjustment tools.
2 Cycle Carburetor Adjustment Kit Includes 530035560
Nov 07, 2014 | Husqvarna Garden
How to adjust air/fuel mixture of bajaj pulsor 220cc
WHY DO YOU NEED TO ADJUST THE AIR FUEL RATIO. HAS IT BEEN PLAYED WITH IF SO IT SHOULD BE ABOUT 1.5 TURNS OUT TO START AND ABOUT .5 TURNS EITHER WAY TO FINE TUNE.
Jun 08, 2013 | Motorcycles
How do I adjust the fuel mixture on the ford 460 efi
The mixture is not adjustable.
You have fuel injectors that are controlled by the computer.
If the check engine light is not on, I would look for a fuel pressure problem or a leaking injector.
Feb 06, 2013 | Cars & Trucks
Saw acts like it is not getting enough fuel, i changed fuel filter, there was dust particles in choke are.
the carb needs to be cleaned out or you need a carb kit to replace all the gaskets. also inspect the fuel lines . if you have replaced the spark plugg check the gap and you might need to adjust the two screws on the carb to set the fuel ratio there are 1 or 2 adjustment screws to adjust this tighten the screw in and it cuts the flow off turn it out and it lets more in play around with it some try turning it all the way in and if it has those annoying caps on the adjustment screws get a pair of needlenose and you can remove the cap and you should have a small flat head to turn in and out hope this helps
Feb 07, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Homelite ST-155 trimmer; fuel air mix out of adjustment (operator error!). Will not start. Cleaned fuel filter, cap filter, added new fuel w/proper mix. Need basic fuel air adjustment to get it started.
do you have adjuster screw's on the carb???
if you do then screw them all the way in then back them out about 1 and half turn then slowly adjust until correct setting's are reached
Aug 18, 2010 | Homelite Garden
Fuel mixture is too lean
many of the late model cars & trucks can't be
adjusted some of the carbs are preset some you can force and some don't have an adjusting screw for the jets if the carb is in good working order but needs a bit more fuel you u must adjust the float for more or less fuel check to make sure the float valve is clean free and not sticking ..
Mar 03, 2010 | 1987 Dodge D150
Miller welder starts fine bur appear to run out gas need help adjuting linkage to fuel control
you need to adjust the throttle governor on the side of the carburetor you will see a adjustment screw do a weld to get the welder to runs at high speed then adjust the screw till it runs continuously, if it still dies out change the fuel filter and try again drain the carburetor bowel if it's diesel replace fuel filter and run fuel threw the water trap.
Nov 18, 2009 | Welding Tools
Garden Logo
91 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
