Question about Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline
Camlink vision 200 voltage requirements - Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline
Are spare feet for Camlink TP24 Carbon Tripod available anywhere?
Try the manufacturer's spares and service department
May 08, 2017 | Camlink Photography
I purchased the magimix vision toaster from England. It has a Europeon plug, can you replace that plug with a three prong US plug?
not as simple as that as the voltage requirements are different
take it to an appliance repair shop for exacting advice
Jan 21, 2017 | Dryers
Is VFR with night vision goggles at night dangerous for civilian pilots?
14 CFR 61.1 (b) (12) and (13) Definitions-Night vision goggles and operations. 14 CFR 61.31 (k) Additional training required for night vision goggle operations. 14 CFR 61.51 (k) Logging night vision goggle time. 14 CFR 61.57 (f) Night vision goggle operating experience. 14 CFR 61.57 (g) Night vision goggle proficiency check. 14 CFR 61.195 (k) Training for night vision goggle operations. 14 CFR 91.205 (h) Instrument and equipment requirements for night vision goggle operations.
Jan 04, 2017 | Aircrafts
Camlink card reader
Are there MAC drivers for this card? If so, install them. If not then this card only works with windows.
Mar 16, 2014 | Computers & Internet
Crt mother board secondary voltage will come 200 wats prblm occur tell any one
The 200 volts is likely a screen voltage source---If the set uses a CRT it is older.
Aside from that voltage in a CRT type monitor no filaments lit in the neck of the CRT can also cause no light on the screen (I assume screen does not light up at all)
A CRT monitor also requires the High voltage to be there for brightness---
There are things you can look at but what is your skill level with this type of equipment?
Dec 20, 2012 | Computers & Internet
TZS-2
The voltage should be good. It is possible the Infra-red emitter tube might be at fault.
The night vision can work under a full moon, so test the vision part to make sure it is working correctly. If you have an infra red/IR remote control for your TB set, you can test the might vision using that remote to see if the night vision is working.
You can use a second working unit to see if the illuminator is actually working. The illumination is not visible light without assistance.
Jan 31, 2012 | Kalinka TZS-2 'Sova-2' Russian Night...
I HAVE NO CAM CODER OR DIGI CAM. BUT I WANT TO MAKE A NIGHT VISION CAM OR GOGGLES . PLEASE HELP ME OUT.
Lets get it right  here.  You don't have a camcorder or digital camera, right!  Then you want to make a night visison camera or goggles   I will tell what you need but you'll need  lots knowledge and know how pertain to electronic, hight voltage, optic lens, and some how getting parts that will be required.
1st. Image intensifier tube, 18mm or 25mm, Generation 1, 2, 2+,3,3+ iit.  You'll need to read up on thes image tubes.  Hint:   Their is electronical engineering in Sweden that built very thing that required for a NV devise....google it.
2nd. ccfl inverter with step transformer.  ccfl invert-cold cathode fluroscent Lamp, inverter electronic switch to turn off the DC voltage  (off/on @ 60hz/sec) or more.  Just with what I have said here.  I could write 200 page on it, and this isn't all of it.
3rd. Need small toloid (sp) coil, or transformer that will step up the Vcc voltage (battery volts) to something in hundreds/thousand volts.
4th. Toloid coil/transformer  take ccfl inverter voltage and multiply it to the operating voltage, frequency, and current the iit (image intensifier tube needs)  Example; 3 battery volt ----ccfl inverter
(where voltage switched off/on (about 3.8 dc volts here with capacitor switch)----- two primary winding (this switch the phase of the two dc voltage, it also has the dc current lage behing the dc voltage by 90 degrees)   Now the primary induces voltage into the secondary windings which is a step winding to about 500V to 1700V  THEN
Voltage multiplier (uses cremiac capacitory HV caps, then diodes (HV)  and they are hook up in a way that look like rome tower-cross hatch pattern---here, there are many different ways to get voltage multiplier, 1/2 wave, full wave,etc.  Now ever two capacitors and three diodes are consider one stage or cascade.  Each stage will double the previous voltage.   Example:  starting with 2000DCV switching to first stage 4000DCV to second stage 8000DCV to third stage 16000DCV to fourth stage equalls 32000DCV.
In this world under conservation of engery; nothing is destroyed or greaded, just engery transfer from one state to another.  Example:  If one could look down the wire from the image tube plate to the end of the battery---one would see resistance/  In the EEEE world it called impendence.  This impendence is made up of wire,capactance, resistances, component resistance everything will contribute to the overall impendence.  Remember the current lag the voltage by 90  degrees.  Simply this lag plays little joke on the impedence--for a short moment in time it makes it look like no current source and before it can reconized it, it off, the process starts all over.  simplist as I can get.
Jul 18, 2011 | US Night Vision Ultra PVS-7B Goggles
The power adapter is bad. What are the power requirements for this unit i.e visioneer 9220 USB scanner
Hello! You can actually get this directly from Visioneer for $19.99.
http://www.visioneer.com/products/parts.asp?PN=9220
Otherwise the power specs in the manual are here.
Power supply Input voltage/frequency 100 Vac, 50/60 Hz (Japan) 120 Vac, 60 Hz (North America) 230 Vac, 50 Hz (Europe) Output voltage/watt 12 V DC, 15 watt maximum
http://support.visioneer.com/downloads/Manuals/9220/9220_Install.OT3.EN.pdf
If this helps, please give a positive rating. Good luck to you!
Jul 01, 2011 | Visioneer OneTouch 9220 USB Color Scanner
I WOULD LIKE TO BUY A POWER CORD AND A USB CORD FOR THE VISIONEER XP200 SCANNER. CAN YOU HELP?
Cut and paste the link below into your web browser and it will take you to a reputable site for the item you need.
Hope that helps.
http://orders.visioneer.com/item.jsp?item=35-0064-000
Mar 09, 2010 | Visioneer Strobe XP 200 Path-Through...
Manual Units Sphygmomanometer Pressure Monitoring MDS9125LF Medline Logo
19 people viewed this question
Top Medline Vehicle Parts & Accessories Experts
Lawrence Oravetz
emankin
 Russ Hill
Russ Hill
Are you a Medline Vehicle Part and Accessory Expert? Answer questions, earn points and help others
