Question about Lexmark C533DN InkJet Printer
My printer says error 1203 catridge error...can you help me with this...I can not find my owners manual?
  • Lexmark Expert
  • 228 Answers
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
Posted on May 19, 2009
On the printer screen it say's error #1203
Error code 1203 means the catridges overflow even it is new or after you refilled them.
Solution:
Use tissue with a few drops of water to dampen and clean off those contact on the holder.
Before printing anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look.
Be sure not to leave any debris of tissue on those holder contact panel.
To reset the error code, disconnect the power cord from the wall. Also remove the power brick from the back of the printer for 60 seconds. Then connect everything again.
Hope it helpes.
Mar 25, 2010 | Dell 946 All-In-One InkJet Printer
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
Error code 1203
it is catridge error kindly replace the catridges.
Nov 24, 2009 | Lexmark P450 InkJet Photo Printer
Cartridge error
Error 1203 is a very interesting error which normally means that your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges.
Solution:
Please let me if this information helped.
Please rate me if you are haapy with the solution.
Sep 15, 2009 | Dell 946 All-In-One InkJet Printer
Error 1203 is a very interesting cartridge error. It means your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
Hope this helps and please feel free to rate me
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
I have a lexmark 5470 model and have a 1203 error.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jul 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
Dell 946 error 1203
In this Case just unplug the Power Supply from the Printer...........
Remove both the catridges from the Printer........
Move the Catridge carrier which holds the catridge back and forth for abt 20 times as fast as u can....
Now Turn the Printer On it will work fine.........
Good Luck...........
Apr 04, 2009 | Dell 946 All-In-One InkJet Printer
Trying to insert new ink catridges
I think it will do the trick for you try this.
or
Mar 31, 2009 | Dell 924 All-in-One InkJet Printer
Lexmark C533DN InkJet Printer Logo
198 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
