Question about Dell 3000cn Color Laser Printer
DELL 3000cn Printing Problems
My DELL 3000cn laser printer is no longer printing completely.  There is a strip on the right-hand side of every page that is left blank.  It's been going on for a week or two.  There is a new black toner cartridge in it.  The yellow is low, but the rest are fine.  A fella at work said it needs a new drum, but I hate to go to that expense if it's not the answer.  Any thoughts?  Thanks.
  • 5 more comments
  • smack48 Oct 27, 2007
    I pulled the cleaning rod out of the side, then slid it back in, and it took care of that problem for me.  Hope it works for you.  I'm having another issue now, but it is not related to the one posted here.
  • Anonymous Nov 08, 2007
    I have the same issue but it is on the right side of the paper. I have pulled the cleaning rod 40-50 times but still has the blank streak down the right side. Could the laser lens be dirty there?
  • no1prez Nov 09, 2007
    I have the same problem. Replaced drum cartridge. Toner is fine. Cleaning rod takes care of the problem for about 10 copies or so and then the blank streak returns.
    Same problem. I've replaced the drum. All toner is good. The cleaning rod takes care of the problem for 10 copies or so and then the blank streak reappears.
  • Kendoggggg May 05, 2008
    Same problem here. Light streak on the right side that the cleaning rod fixes for ten copies or so. I recently had to replace the drum cartridge because it ran out, but the problem was not affected at all.
    HELP!!!
    Ken R
  • robots Jul 09, 2008
    have the same problem. Test out all the suggestion above. It did not help. I went thru the diagnosis test for all colour. The streak happens on all colour. It mentioned it would have been problem on the laser unit. Does it mean that it is no way to correct this without big expense like purchasing a new one?
  • Anonymous Oct 29, 2008
    Same problem. Printing but leaving a steak on the right side. The streak is faint.
    Problem Solver:
  • 4 Answers
Switch off the printer then switch on again whilst holding the UP and DOWN menu scroll buttons simultaneously.
Then you can go to a TEST PRINT area and print off pages of idividual colour.
If the streaks appear on ALL prints its likely to be the laser unit. If the streaks only print on the COLOUR sheets ( not BLACK) then the problem lies with the drum or the transfer belt.
Remove the drum and turn it manually with the gog at the side and give it a clean with a soft LINT FREE cloth, do the same for the transfer belt and then you may have to run a few test prints to get it all reprimed but you should be OK.
Posted on Jul 07, 2008
I have the same problem. Test out all the suggestion above. It did not help. I went thru the diagnosis test for all colour. The streak happens on all colour. It mentioned it would have been problem on the laser unit. Does it mean that it is no way to correct this without big expense like purchasing a new one?
Posted on Jul 09, 2008
I had the same problem and pulled out out the cleaning rod like was suggested on this site and it had some red toner on it so I wiped it off and now it works fine. Maybe try rubbing the rod with a dry cloth, might be something on it that can't be seen.
Posted on Nov 19, 2007
An Empty Stripe along the right side of portrait setting
Have you tried a new toner cartridge? There is a couple possible culprits.
Thanks,
Lee
Jul 19, 2008 | Dell 3000cn Laser Printer
Installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
Changing Dell 3000cn printer cartridge
The instructions always come with the new cartridges and also are printed on the new cartridges. You move the right hand (colored) side up to unlock. Carefully pull the cartridge up and out (you can screw up the gears if you don't put the cartridges in and out straight. Make sure you've followed the instructions that come with the new toner cartridge (removing tape, shaking), put it in the same way and move the right hand side down to lock.
Apr 07, 2009 | Dell 3000cn Color Laser Printer
DELL 3000cn Printing Problems - Black text is very light
It sounds like the font that is being used is too light, not dense enough. Is there a default density or toner save function on this printer? Check the settings from the control panel.
Jan 26, 2009 | Dell 3000cn Laser Printer
Printing
Try the settings in the printer.
Push Menu button till you see menu
then the down arrow around the enter button till you seetray settings - hit enter
go the paper size - hit right arrow
hit down arrow to the MPF then hit right arrow
then down arrow to change to "letter" size
Good Luck
Aug 15, 2008 | Dell 3000cn Color Laser Printer
Printing problems in a 3100 colour lazer printer
This could be caused by the scanner(printhead) image drum or fuser.
May 18, 2008 | Dell 3100cn Laser Printer
Printer Problems
From experience with similar machines, it sound very much like either contaminents in the optical path or a scored drum.
May 09, 2008 | Dell 3000cn Color Laser Printer
Dell 3000cn Color Laser Printer Logo
1,643 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
