Question about Electrolux Over-the-Range Microwave
Keypad on new Electrolux microwave is hard to push!
How do i fix keypad
Keypads will flash when new oven or when disconnected and setting are lost. First try setting the clock
  • push CLOCK--enter numbers--push CLOCK to see if keypad becomes operational.
If not, unplug, replug and try again. As for "fixing" keypad ....that is not likely to be the problem and even it it were, keypads are not user repairable. For further info, dial the the factory customer support phone number.
Mar 14, 2015 | Microwave Ovens
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
Electrolux high speed oven quit beeping
The buzzer on the keypad control has opened, or one wire has come off due to poor soldering, or the voltage to the buzzer is missing.
Jul 18, 2012 | Electrolux ICON Microwave Combination Oven
I have a GE Microwave and while pushing button the keypad locked and i got the message CONTROLS ARE LOCKED - how do i get out of this? I can't clear it and the buttons don't respond to touch. Kelley
If a hard reset (unplugging power for 2 minutes)does not fix it, then you have a failed membrane keypad.
To give you any further free help, we would need your full model number form the tag in or on the unit.
Please make a new post with that your full model number and symptoms.
Jan 28, 2011 | GE Microwave Ovens
How to replace the front buttons?
Most microwaves use a membrane type keypad that is glued to the front panel..they can be expensive though, but aren't too hard to replace...it involves removing the cover...unplugging the keypad ribbon cable...removing the old keypad...and reinstalling the new keypad
Jan 15, 2011 | Sharp R-1500 Microwave Oven
Worth fixing 9 yr old unit? Told the keypad going bad. Often powered off/on to reset is required. Expensive repair?Complicated? I am quite handy if part swap is an option. I recall hearing a microwave is...
Hi - I really do not like to condemn any machine however microwaves have become very inexpensive - more efficient - quieter and packed with more features than ever before for a reasonable price. If you are handy unplug the unit and remove the front panel (a few screws ) at the keypad to expose the keypad harness, please check the harness connection. It is not uncommon for a keypad to fail. If the keypad still fails I advise purchasing a new machine simply because the parts, shipping etc will likely exceed the pro rated value of your machine. I know it is hard to let go sometimes but in the case of old microwaves it is generally wise. Microwaves can last well over 10 years. The good news is you will be getting a warranty with your new one should you decide to go in that direction. Hope its the harness, Sincerely Brian
Nov 26, 2009 | GE JEM31 Microwave Oven
LG microwave LMVM2075ST panel started acting crazy after I cleaned it. Will not do anything if I push a button except beeping noises. Any suggestions as to what is going on with this machine? Should I try...
liquid probably has entered keypad laminate; causing a short. unplug unit, direct warm hairdryer to entire keypad; plug back in; and hope for the best. if no luck; replace keypad. also never spray anything directly onto keypad; always clean with a moistened towel with light force.
Sep 07, 2009 | LG LMVM2075 Microwave Oven
Will not heat at all
Could be the "board". Well known for failure. Get the part number from the board & search eBay for NEW board.Instructions probably on youtube
Mar 05, 2018 | Electrolux Over-the-Range Microwave
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
Problem with Frigidaire CPLMV168CC1 Over the range microwave
I would suggest a hard reset - unplugging it for a few minutes then trying again.
If you don't have the owner's manual, you can download it here:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316137207en.pdf
If it doesn't have an option to turn sounds on and off, you may have a problem with the keypad or control board.
Moisture may have gotten into the controls from steam (from not using the exhaust fan while cooking on the stove top) or spray cleaner (from spraying the keypad directly instead of spraying it on a soft cloth).
Please reply back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 07, 2008 | Microwave Ovens
Electrolux Over-the-Range Microwave Logo
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
