Question about Dryers
I'm getting burn marks on clothes. Think it's the seal on the back of dryer? Must hang to dry all white clothes, so what's the point o fhaving a dryer?
  • 864 Answers
The gasket between the drum and the back panel may be worn or missing.  I had a similar problem with a 34 year old dryer when the felt gasket wore out and allowed metal-to-metal contact between the drum and the back panel.  The clothes would get pinched between them and make a black "kiss" mark.
Posted on May 20, 2009
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
My clothes are leaving the dryer with streaks (maybe 4 or 5 inches long) that appear to be burn marks. Closer inspection of the inside of the drum shows that the back "wall" of the drum is off-center...
I have the same problem and read somewhere to replace the felt belts. We have done this twice and still getting the brown marks. I have found using Goo Gone and/or Dawn dish soap and scrubbing with a brush will take most of the mark out, re-wash and HANG to dry. I'm still looking for a permanent solution to this problem, as much as these dryer cost and you can't dry white clothes???
Jun 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer is not drying the clothes all the way and it is leaving little brown marks on my white clothes.
sometimes lint can build up on the back side of the dryer drum and get burned then the dryer will dump the burnt lint in the drum . most dryers have a double element and when the one side goes it breaks in two and only puts out half the heat if you are mechanical take it apart good tip take pictures with a camera and white paper tape to label wires if attempting to take apart un plugg
Jan 14, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer 65291, burn marks
The problem you describe is usually caused by a rear drum seal worn and pinching articles during part of the drum's rotation. Replacing the rear drum seal is covered in great detail at the link below. Be sure to follow all links in blue that pertain to your machine. Caution: The glue that comes with the seal is VERY sticky and messy and comes out faster than you'd like at times. Do not get it on areas and items you're not prepared to discard. It is VERY difficult to remove once dry and it dries very quickly.
Rear drum Seal replacement procedure
Oct 02, 2009 | Kenmore Dryers
Burning marks on clothes in dryer
how old is dryer. drive belt may be slipping. Unit may have a faulty control that allows element to superheat. You have a potential fire hazard. What type of clothes are getting the burn marks? Should they be dried in a dryer?
Jul 02, 2009 | Dryers
Brown lines on clothes (whites and lights) from the dryer
you need the top seal replaced it is wore and clothes are getting stuck in the front seal...
if you are handy you can do it yourself...
Jun 17, 2009 | Frigidaire FTF2140FS Front Load Washer /...
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Burn marks on clothes
problem is caused by drum seal usually the back one look closely at seal to see if there appears to be rust if so replacedrum seal ..clothes ten to rub against it while in motion causing brown streaks..would replace both front and rear just to be sure front doesn't give problems soon
Jul 26, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Dryers Logo
191 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
