Question about Hoover Washing Machines
Error code hO1 on Hoover washer dryer
Error code of h01 on dial will not go away
4 Suggested Answers
SOURCE: Hoover washer/dryer VHW854D SHOWS ERROR
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Posted on Dec 20, 2010
SOURCE: error code E11 on hoover
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Posted on Dec 23, 2010
  • 11 Answers
SOURCE: Does the Hoover HW160M washer/dryer
No vent hose required
This appliance condenses the water vapour to a liquid and punps it down the drain.
Posted on Jan 30, 2011
Testimonial: "Excellent response and knowledgeable answer- exactly what I needed to know- thankyou 10/10."
Hoover washer dryer wd 9616c error code e13 and burning smell from the rear????
The automatically suggestted E13 guidance that the system posts referring to Bosch machines is irrelevant I'm afraid. On a Hoover, the message means "Faulty module connections. Check all connections between modules and associated wiring." The chances are that you have a partially dislodged connector on the main board, or on the connector that goes to the motor
Oct 14, 2015 | Hoover Washing Machines
What does Ho1 mean on the screen?
Some Bosch dishwashers have a time delay option. The H01 indicates a one hour delay has been selected. Press the Delay key several times until you see H00 in the display. Then try to start the dishwasher cycle you need. Bosch error codes tend to start with E.
Please add a comment with the model number of the dishwasher if you need additional help. (Without the model number, I can't be sure which key sets the time delay. On some models, the key is near the On/Off button. On others, it's closest to the Start button.) I hope this helps.
Sep 03, 2015 | Bosch Dishwashers
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
ERROR CODE H02 ON MY HOOVER SENSOR DRY WASHER DRYER WD9616C
Hi I have the error code ho2 on my Hoover wash machine does any one no what it means
Oct 21, 2012 | Washing Machines
Hoover washer dryer error code h01
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
Sep 12, 2012 | Hoover Washing Machines
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
Does the Hoover HW160M washer/dryer need an exhauest duct to carry away the water vapour from the dryer?
Jan 10, 2011 | Hoover HW160M Front Load Washer / Dryer
Zanussi Washer Drier
We had same problem with same model machine - basically you have to ignore the letters behind the see through plastic window and write new ones around the dial with a permanent marker that you know are correct and correspond to what you want. It's a lot of trial and error - try and go for the simple dryer function first and mark write the corresponding letter against the dial straight away, then work out the distance between each letter on the proper dial and and you should replicate these distances and letters with your pen.
Jun 30, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
Need to know what the programme numbers mean please!
Here is the Hoover site where you can download an instruction manual. http://service.hoover.co.uk/manuals/?Section=2 I had no idea Hoover made washers, dryers, or combo units. They only sell vacuums on this side of the pond.
Apr 21, 2009 | Washing Machines
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
