Question about Hoover F5906-900 Upright Steam Vacuum
Hoover steam cleaner leaking!
I am trying to use a Hoover Steam cleaner upright carpet shampooer and as soon as I put in the clean water tanks it leaks everwhere out of the underneath! I hae no Idea what model just that it is pright and gray and purple. HELP!!!!!!!
graemevm
  • 519 Answers
SOURCE: I have a Hoover Deep Clean carpet shampooer but
Click on the following link and scroll down the list of Steam Vac models to find your specific one. Then click on the red characters which represent your hoover situated to the left of your specific model:
http://www.hoover.com/CustomerService/Manuals/Default.aspx
Best wishes,
Graemevm
Posted on Jul 03, 2010
  • 3 Answers
SOURCE: hoover F7431-900
I had the same problem. Turned out to be so simple. Look down at the machine. On the right is the green spiral to indicate the wheels are turning. Right above that is a cover that can be popped off to allow access to a small filter. If the filter is blocked, air intake is blocked, and the brushes will not turn. Mine was clogged. Took the 2 seconds to remove the material and the machine was fixed!
Posted on Aug 04, 2007
Agent Don
  • 310 Answers
SOURCE: brushes do not rotate on
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
Generic problem for all Vacuums
Brushes do not rotate on
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 09, 2008
CorvetteKing
  • 108 Answers
SOURCE: lost manual for hoover steam vac
You can find that manual on hoovers website (hoover.com) it is under customer service/parts.
Best of Luck
Posted on Jun 14, 2009
  • 97 Answers
SOURCE: Hoover Steam Cleaner - dirty water is not coming up in the tank!
recovery tank (dirty water tank) not on correctly
Posted on Jul 20, 2009
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Solution for "hoover steam cleaner keeps
Hoover Carpet Shampooer
You might just need a new gasket. THey are inexpensive and fairly straight forward to replace with the right tools.
Sep 10, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover Upright Steam Vac, 12 amp
  • Check to make sure that the lower dirty water lid is installed and secure and not cracked.
  • Check to make sure the front duct panel is installed on the dirty water tank (this will transition the water from the front nozzle into the tank)
  • Check the filter in the dirty tank lid, clean if necessary
  • Remove the lower tank and look at the motor cover, locate a round hole, you should see a black ring (gasket).
  • with the lower tank removed, turn the machine on to check suction at the round hole, if OK then your problem will be with one of the above reasons
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
There is no steam on my hoover steam vac
They do not really "steam." They use hot water to clean your carpets with a mix of cleaner as well. You will not see your unit actually steam.
Dec 09, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Steam Vac clean water tank valve leaks
a) make sure that there is not a place for a stair attachment. If
there is make sure air is not leaking through where the attachment goes
on because of damaged or misplaced fitting.
b) some steam vacs leave water behind them and **** up in front of
them. If you just walked forwad with the steam vac nothing would be
sucked into the tank.
c) try taking your finger off the trigger and using the steam vac. If
the tank still empties the trigger is stuck open.
d) try putting clean water in the dirty water tank only and using it on
a dry rug. If water goes somewhere from the dirty water tank you have
a leak.
e) take apart what you can and look at the parts. A good visual
inspection can solve many of these types of problem if you are careful
not to miss anything.
Nov 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
IWOULD TO KNOW IF STEAM CLEANER ARE HEATED WATER
yes, they heat water to over boiling point by putting it under pressure so you only get steam. it cleans with very little water.
Jul 27, 2008 | Vacuums
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5906-900 Upright Steam Vacuum Logo
294 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
