Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Clicking sound a delay in turning on a Samsung 46 inch LED1080 flatscreen tv
rlamkin
  • 44 Answers
SOURCE: 46" Samsung TV loses sound.
R U using HDMI? If so that be the problem.
Posted on Jul 03, 2008
SOURCE: Samsung 50" plasma won't turn on
My 42" plasma is making a clicking sound, then it switches off and keeps clicking but not switching back on, when it does go back on it stays on for just a few moments, it is only 14months old.
Posted on Dec 04, 2008
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 541 Answers
SOURCE: SAMSUMG 46'' LCD TV MODEL LN46A530P1FXZA PROLEM
Check for bad capacitors in the power supply. The capacitors will be bulged on top. Typically there will be 3 or 4 caps with this problem. Thanks for using fixya.
Posted on Jan 23, 2010
SOURCE: 3 year old Samsung 40 inch LCD TV will not turn on
The problem is 4 capacitors on the power supply board. Just had mine done under warranty. They (Sears) replaced the whole power board but you can get larger capacitors and just replace those for alot cheaper if not under warranty.
Posted on Jan 30, 2010
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
No power Samsung flatscreen CRT 21 inch TV
Check its fuse. Check the rectifier diodes. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 18, 2014 | Televison & Video
Samsung UN40ES6100 HDTV has a sound delay that I can't get rid of
My LCD panel is broekn? is it work to replace the LCD panel ?\
The Replacement LCD panel code is BN95-00604A
How to do the LCD panel repleacment
Jun 12, 2012 | Samsung UN40ES6100 40 Inch 1080p Smart TV...
I have samsung led 46 inch is not tur on but hear clicking
no power and clicking usually is a power supply problem. Your power supply is clicking tring to turn on but its not. You will need to replace teh power supply.
You can get get parts for this tv at www.interliquidparts.com
Aug 28, 2011 | Samsung LN32A330 32 in. LCD TV
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a 46 inch Samsung LCD model number LN-T4665F and I have been having issues w/ the power/ clicking sound! It used to turn on and clicked a few times now just clicks all the time and doesn't turn on...
1. It is not a two years old TV, but a 9 years old one.
2. The common problem of the symptoms is a defective main power supply, you may check to see that are there anny "Pup-Up" electrolytic capacitor on the power supply, if there is any, replace them, you may fix up the TV
Jul 02, 2017 | Samsung LN-S4692D 46 in. LCD HDTV
When i turn on my lcd flatscreen tv it makes a clicking noise
Firstly, take a quick look at the back whenTV turns on and see if there is back light or not. If no back light, the most suspective board is power supply. If it has back light, it needs more steps to find out exactly defective board.
Aug 16, 2009 | Televison & Video
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
15 people viewed this question
Jerry Greenberg
Jerry Greenberg
