Question about Dryers
It is a whirlpool gas ultimate care II dryer i think it is lgq9858pw.... problem not drying.. it sounds like a rattle when you would think the burner is starting... just went through the unit and had it firing as usual but the first time when moved back in place it stopped firing, the second time when i placed the back on again it stopped firing.... removed the lower front plug and i can see after a few seconds the ignitor starts to glow.... but the rattle continues... is this a gas inlet problem or is the glow not correct... please help wet clothes do not wear well!!!!
  • 1 more comment
  • vmans2442 May 19, 2009
    any idea of the cost... ballpark... and the best way to access the location of this solenoid coil area?
    now i am going to be stupid, what is the best way to disassemble that unit from the back... do you have a link for that? and thanks for your help to this point.
  • vmans2442 May 21, 2009
    i used a wrong model number previously.. my problem is a gas dryer that will fire to temp, but after the first fire when the unit is to fire again you can here it start then it rattles... the ignitor glows... previously i recieved info for a different model and i was wrong.. for the correct whirlpool model lgq8858jq1 does it still sound like the solenoid, and if so could i get conformation and info on how to change this part out and ballpark cost. thank you
    Top Expert:
  • Dryers Master
  • 77,514 Answers
The problem here is most likely the air temp sensor (this is generic to all dryers) is defective and signaling the gas control valve to shut off the gas flow. I recommend you replace the air temp sensor, also make sure the dryer air vent is not obstructed this will cause this problem as well. go to the following link to get advice and parts to fix this problem.
http://www.repairclinic.com/
Posted on May 21, 2009
  • 6,784 Answers
Hi, the ignition is fine, this is an issue concerning the gas solenoid coil assembly. the rattle is coming from the coils. they activate the solenoids, which, open and close the gas valves. Simply replacing the gas valve solenoid coils with fix this issue you are having.
You can buy a Burner Assembly 60 Hz Gas valve solenoid coil kit that will replace the entire assembly or, you can just order the Gas valve solenoid coil kit.
Posted on May 19, 2009
  • 3 more comments
  • Michael Masters
    Michael Masters May 19, 2009
    I have located a coil kit and you can order this kit form this link if you choose.
    GAS VALVE SOLENOID COIL KIT
    Now, if you choose to just replace the entire Burner assembly, use this link below.
    Burner Assembly 60 Hz.
  • Michael Masters
    Sure, i have posted links above that will direct you to purchase pages with the appropriate price info. the location of the burner assembly is in the same proximity as the glow ignition module. you will have to approach it form the backside of the unit. make sure you shut off the gas when disassembling the assembly.
  • Michael Masters
    the coils are part of the burner assembly. its a integrated design.
  • Michael Masters
    The burner assembly will be on the backside on the bottom right hand corner. the coils are sitting on the top. they will look like two cylinders with wire contacts. I have also located a diagram that will help. its exploded for a good view. click below to access. the cabinet break down is on page 3.
    DRYER DIAGRAM
  • Michael Masters
    There are screws on the back panel that you will have to relieve. this will release the back panel and you can gain access from there. the diagram pdf link i posted will show the back panel and the Hex screws holding the back panel on. its on page 3 of the pdf file.
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    My 10 year old electric dryer (Whirlpool Gold Ultimate Care II) is making a squealing, rattling noise. It still heats up, but something sounds loose. I wondering if I should get it fix or replace it.
    Here is a tip that I wrote about dryers and noises...
    It will help you determine what is happening there...
    Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
    heatman101
    Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
    Aug 19, 2011 | LG DLG2524 Gas Dryer
    Looking for a manual/user guide to a Whirlpool Ultimate care II dryer , model #LGQ9858PW and washer, model # LSW9750PW. Any thoughts or suggestions? thanks tbodee@hotmail.com
    Hi, There are two slightly different models for your dryer there will be a '1' or a '0' after the PW, the manuals can be found ---> HERE <--- for the dryer.
    There are 4 slight differences for the washing machine, there will be a '0' , '1' , '2' or '3' after the PW all the manuals can be found ---> HERE <--- for the washing machine.
    You will need Adobe Acrobat Reader to view these manuals, if you don't have it you can click the link near the bottom of the pages where the manuals are, or you can ---> Click Here <--- to get it and then install it so you are able to view the manuals afterwards.
    Hope this helps. (: don't forget the thumbs ups if it did :)
    Midge.
    Feb 20, 2011 | Whirlpool Dryers
    My whirlpool ultracare !! dryer will not heat. I have to dry things over and oer and over til they finally dry.
    i looked up your model number and that's to a washer not a dryer.if it's a gas dryer it sounds like you have bad gas coils located on top of the gas valve.the coils work until they heat up like in the first 15 to 30 minutes and they shut down,when they cool they work again until they heat up and fail,this is why you have to keep running thedryer,one more problem could be the dryer needs to be cleaned out.clean out the vent line,clean out the duct that the lint filter slides into and vac out the cabinet where the motor is
    Jan 22, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
    I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
    I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
    Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
    I have a whirlpool gold ultimate care II electric dryer and have to dry everything on high twice to get it dried. any suggestions?
    first how is the clothes out of the washer? That might not be spinning fast enough in final spin. When was the last time the dryer vents was cleaned. Do you have a flow out the vent? If so then something might be going on with sensors.
    May 18, 2009 | Whirlpool GGQ8831L Gas Dryer
    Whirlpool ultimate care II dryer will not dry clothes
    does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
    Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
    Hello gigiknoll
    Welcome to Fixya
    My name is Huum,
    This model should be electronic ignition and does not use a pilot light.
    The igniter may be faulty.or the gas module may be faulty.
    Pilots are a thing of the past!
    This requires a tech to test it with equipment.
    Thank You For trusting us with your question
    Please remember to leave a solved rating before you leave!
    Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Dryers Logo
    146 people viewed this question
    Top Dryers Experts
