Question about Canon PowerShot A520 Digital Camera
Canon powershot sd750
My SD750 refuses to power up. It has not been damaged in any way. ANY SUGGESTIONS?
  • westfordus Feb 16, 2009
    My sd750 will not power up, changed the battery in case it was a battery problem, but no change. Can someone help?
    Scholar:
  • 80 Answers
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Posted on Dec 23, 2007
SOURCE:
Canon Powershot SD750 powers up fine; lens extends fine. The LCD is black. I can see a faint image - enough to enter the menu and change settings. Increasing brightness has no effect. Seems like the screen...
It's not the screen, but its backlight that is the problem. It's likely a poor connection of the ribbon cable in its connector socket. This problem will require either professional repair, or your opening the case to reseat the backlight ribbon cable in its connector. Here's a disassembly of a somewhat similar SD600 to give you an idea of what's involved.
Sep 28, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a Canon PowerShot SD750. I dropped it and
If this is the case, the camera might have internal damage. Might be better to send it back to Canon delears/shop for repair. Please try below link
Canon
Jul 27, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera won't turn on
camera must be damaged and sent back to manufacture.
Feb 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My daughter vomited on my Canon PowerShot SD750 (Black)???
Get an estimate of the repair cost and then decide whether to get a new one or not.
Aug 12, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error restart camera SD750
somebody saying under warranty
http://www.digitalcamera-hq.com/digital-cameras/canon-powershot-a570is_question.html?qid=12688
May 30, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
No power on Canon SD750
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Jan 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon powershot SD750 will not turn on.
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Nov 21, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon sd750
send it to us for a free diagnosis this power issue is very common. we can fix for for normally 85.00 worst case 125.00 depending on the issue 85.00 replaces the fuse or mainboard.
Jul 02, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon power shot SD750 basic user guide
My Canon Powershot SD750 Elph..
The Date Stamp is grayed out so I can't turn it on. Have any advise on how to get this to work?
Thanks.
Sep 02, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot A520 Digital Camera Logo
57 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
