Question about Peg Perego A3 Newport Standard Stroller
Where can I find replacement parts - front wheel assembly
Both front wheels broke off and I am having a hard time finding replacement parts. The plastic that connects the wheels to the stroller are broken
  • 127 Answers
Call perego at 1800-671-1701,they havy any parts you need in stock.
Posted on May 19, 2009
3 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
You can search and purchase a replacement part : http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
may this help!
Posted on Jan 23, 2008
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Posted on Feb 11, 2008
Upper rack track wheel broke
You can try to obtain the part from KitchenAid or an appliance parts supplier. However, you may only be able to get the complete assembly.
Nov 07, 2013 | KitchenAid KUDS30IX Dishwasher
Front wheel bearing on 2 wheel drive replacement
It's a hub style bearing assembly bolted to the steering knuckle. After you have the wheel removed, remove the brake caliper and the brake rotor. Disconnect the Wheel Speed sensor connector under the rubber inner wheel well on the top of the frame. Nice part of the two wheel drive the bolts in behind the steering knuckle are easily accessable. After the hub is unbolted, it may take some hammering to remove the hub assembly from the knuckle. they do seize in at times. After the old hub is out, clean as much of the corrosion out of the knuckle cavity and maybe a light film of antiseize to make the next time easier. Reverse the procedure for assembling.
This is simplified. Have any more questions, just drop me a line.
Good luck
Aug 05, 2011 | 1999 Chevrolet Silverado 1500
Four wheel drive wont engage. Tranfer case is
Sounds like you either have a vaccum leak or your 4 wheel drive actuator is not working to engage the front differential.On my 98 ram there is a black and red plastic lines that are used for the vaccum lines. They are underneath and go from the transfer case to the front axle, check to see if one or both might be cracked or broke completely.If the lines are good then it could be your actuator on the front axle. A new one is about $93 at advance auto parts and not very hard to replace
Dec 15, 2009 | 1998 Dodge Ram 1500 4WD
Just wondering if i can tow a ford f-150 with 4 wheel drive and with the front tire off the ground or also known as a car dolly or will it damage my truck????? also wondering about my power steering pump...
1. If you disconnect the transmission , no.
2. Either your steering shaft - relatively cheap and easy to replace - or the steering box - expensive and hard to replace - are at fault. How was your luck lately?
Nov 19, 2009 | 1988 Ford F 150
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Front wheel bearing/drivers side
If the truck doesnt have a hub assembly then just pull the wheel off and pull the rotor off the bearing will be inside the rotor on each side. If it is a hub assembly then you have to buy a whole assembly and its made in it.
Jan 02, 2009 | 1999 Ford F250 Regular Cab
Grinding sound in the front end
I had this problem in my 2005 F-150 twice! The first time was covered under the warranty and the second time was out of my pocket! ( close to $500.00!) There is a solodoid u[pp on the firewall that gets water into it then it corrodes the lines and such. Ford dealership replaced 2 valve assemblies, 2 actuator assemblies, and the IWE Solonoid to fix mine. They claim the problem will not come back but that remains to be seen.
Sep 22, 2008 | 2005 Ford F-150
Hope this helps.
Jan 13, 2008 | Baby Gear
Peg Perego A3 Newport Standard Stroller Logo
272 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
