Question about Sewing Machines
How to use buttonhole maker on kenmore 385.12814490
Don't know how to use the sewing machine to set up for buttonhole maker
SpotBert
  • 231 Answers
SOURCE: white sewing machine model 2999
Winter 2002 was when it was first released. Retail of $499.00.
Contact White Sewing Directly for parts =>
http://www.whitesewing.com/customer.asp
Posted on Jan 04, 2009
SOURCE: making a buttonhole on a Necchi 3204 sewing machine
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Posted on Mar 04, 2009
SOURCE: machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Posted on May 27, 2009
  • 21 Answers
SOURCE: My Janome sewing machine has a buttonhole
Pull the BH (Buttonhole lever) down which is to the right of the needle bar.
Posted on Feb 11, 2010
SOURCE: I am trying to make a buttonhole using the
if you have a automatic buttonhole , then you should have a buttonhole lever that you have to pull down, before you start to do the buttonhole,, my machine will not let me do a buttonhole unless I pull down the buttonhole lever
Posted on Nov 17, 2010
How do I operate the automatic buttonhole maker on my Kenmore 1901?
Hello Sewing Guild
A 1901 Kenmore is probable this one, and a downloadable manual is available free here:
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/38516120200.html
Please let me know if this was helpful.
Happy Stitching
Sewingirl/
Mar 09, 2017 | Kenmore Sewing Machines
I need to know what the settings need to be on the Kenmore 158 machine to use the buttonholer?
You'll have to provide more information about the sewing machine. 158 indicates the manufacturer. However, there are a lot of Kenmore sewing machines from that manufacturer. The 158.1340 manual is available here: https://www.manualslib.com/manual/150291/Kenmore-1340.html .
Page 40 (41 in the linked format) begins the section on buttonholes. With the buttonhole attachment, you need to set the stitch to the second narrowest zig-zag stitch. You can use any stitch length. The description of using the buttonhole attachment starts on page 45.
Without the buttonhole attachment, you set the stitch selector to each part of the buttonhole as you reach them. The stitch length dial has to be set to an appropriate length in the block for buttonholes. The top and bottom tack bars use the same stitch selector. There are separate ones for the left and right sides of the button hole.
I hope this helps. Please add a comment with the rest of the model number on your sewing machine for specifics with your machine.
Jan 04, 2017 | Kenmore Sewing Machines
My 4423 will not advance when I have all the settings set to sew a simple buttonhole. Why?
do you have a manual?
do you have the buttonhole lever pulled down?
if these suggestions don't help then the machine needs to be checked at a sewing machine shop
May 26, 2012 | Singer 4423 Sewing Machine
I'm trying to sew my first buttonhole. It sews briefly then 6L comes on the computer and it won't complete the buttonhole What am I doing wrong?
Make sure you pull down the buttonhole lever from the underside of the machine (near where the needle threader is) If you don't do this, the machine will make a few stitches and then stop. with error 6L.
thanks for using fixya.
May 28, 2011 | Kenmore 19110 Computerized Sewing Machine
I do not understand how to use make the the buttonhole i cant get the 2&4
According to the description for the 15218 sewing machine, it has a one-step buttonhole function. You should be able to put on the automatic buttonhole foot, insert the button behind the presser foot, and set the pattern selector dial to "BH"- see p. 66 of the manual at http://www.managemylife.com/mmh/lis_pdf/OWNM/L0909499.pdf
Mar 05, 2011 | Kenmore 15218 Mechanical Sewing Machine
Kenmore 15516 It only goes reverse both ways.
Does it have an automatic buttonhole? If so, is the pattern selector set on part of the buttonhole? set it to straight stitch or Zig Zag
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Reverse Switch Control on my Kenmore Sewing Machine
My back swith button is not working on my Kenmore sewng Mchine. Can you tell me what the problem is?
Aug 25, 2008 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
