Question about Dishwashers
Maytag dishwasher wont fill
Dishwasher wont fill I've already changed out water inlet valve
  • 465 Answers
Some dishwashers have a float inside that shuts off the water when it reaches a certain level check to see that the float is not stuck in the high water ( off ) position. Hope this helps.
Posted on Jan 01, 2014
4 Suggested Answers
  • 131 Answers
SOURCE: Maytag Performa dishwasher
Check the float switch.
Posted on Mar 10, 2008
SOURCE: Bosch SHU 4000 series dishwasher; Water keeps on filling
Follow-up: I was able to fix the problem on Bosch model # SHU 4002UC. Purchased water inlet valve (part number 425458) from Sears Parts Center. I required the Sears unit number from the original invoice as Sears computer system apparently cannot identify the Bosch model number. The valve is as described by meyerjr above; however it is located at the bottom front of the machine so could be replaced (not so easily) without removing the machine. Cost of part was $30.50 Cdn including tax.
lwou
Posted on Apr 20, 2009
fleetsbarber
  • 6 Answers
SOURCE: how do you test your dishwasher's water inlet valve?
find the tech sheet and ohm out the valve with a multimeter. or pull off the plug, and connect a multimeter to it. select a cycle, hit start, shut door, wait a few minutes and you should be getting 120VAC out of the plug. if the voltage is there and the no water is entering the machine, faulty valve.
Posted on Oct 02, 2012
Dishwasher wont let water come in
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Dishwashers
No water in dishwasher
I would suggest to check the information by clicking here if you are planning to DIY.
May 20, 2008 | Dishwashers
When you turn on the dish washer it heats up but there is no water coming into the machine- quiet series 300
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Daniel
May 07, 2011 | Maytag Dishwashers
Dishwasher runs but gets no water...
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Jan 31, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwasher will not fill with water. What could be the problem?
Dishwasher will not fill with water .
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
For trouble shooting click this link:--- http://www.partselect.com/dishwasher+dishwasher-wont-fill+repair.htm ----------- Thank you.
Jan 24, 2011 | Maytag Dishwashers
Water will not fill the dishwasher, it runs but it will not fill with water...is the water inlet plugged?
Hello there
The most common causes of this problem are a defective water inlet valve or a stuck float switch. The float switch sits under the dish racks and sends a shut-off signal to the dishwasher when the water level is high enough. Make sure you only use a Maytag-compatible replacement if you have to change out your dishwasher's float switch or water inlet valve.
Difficulty: Moderate Instructions Things You'll Need:
  • Owner's manual
  • Screwdriver
  • Scrub brush
  • Replacement parts (if necessary)
hd_clickable2_area.gifGet what you need for every
project at HomeDepot.com
  1. 1 Shut off power to the dishwasher from the home's circuit breaker box. Remove the lower rack from the inside of the dishwasher.
  2. 2 Check the water inlet valve to see if it clogged or broken. Replace the valve if you notice any problems and test the dishwasher again. If it still does not fill, proceed to Step Three to troubleshoot the float switch.
  3. 3 Consult your owner's manual to find the location of the float assembly. Remove the cover, if applicable to your dishwasher. There may be retaining screws holding the cover in place or it may just snap off.
  4. 4 Hold both sides of the float while you raise and lower it several times. The float should move freely without binding or catching on anything. Disconnect and use a scrub brush to clean the float if you feel any resistance.
  5. 5 Reattach the float and test its movement again. If it is still not moving properly, replace the float.
  6. 6 Replace the lower rack of the dishwasher and turn the breaker switch back on.
Read more: How to Troubleshoot a Maytag Dishwasher That Does Not Fill ' eHow.com http://www.ehow.com/how_6284004_troubleshoot-maytag-dishwasher-not-fill.html#ixzz1A891ccai
Jan 05, 2011 | Maytag MDB6769AW Builtin Dishwasher
The dishwasher goes through the cycles but will not fill with water on some cycles.
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Oct 20, 2010 | Maytag 24 in. MDB5600A Jetclean II...
No water filling into dishwasher
Hi not to be rude, but have you checked the water inlet valve (might not be turned on) also you might check the water line going to the dishwasher it`s self it might be crimped, or you could check the water inlet on the dishwasher , I think that the fill valve might be stuck also. Hope this was helpful.
Mar 20, 2009 | Maytag 24 in. MDB3000 Built-in Dishwasher
I have a Maytag dishwasher model DWU8860 and it doesn't always fill after a pumpout cycle
It is probably a faulty inlet valve. Check the float switch first.
See here how to locate the parts.
See also this advice for repairclininc:
" There's no water entering the machine If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Sep 06, 2008 | Maytag Dishwashers
Maytag MDB6650AWW will not fill
My Maytag MDB6650AWW dishwasher would not fill. The lights on the panel were on when I tried the wash cycle. I tested the water valve but no voltage was found during the cycle. I thought it may be the timer/control circuit. I traced the power from the door switch and found no power going to the float switch leg. I found two wires completely cut through (one going to the Water Valve) and three others partially sliced.
Nov 03, 2007 | Maytag 24 in. MDB7650AWS Built-in...
Dishwashers Logo
Top Dishwashers Experts
