Question about Jandy Pool & Spa
Pump whining - Jandy Pool & Spa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Need a new pump or pump motor dont forget the seals
Posted on Sep 21, 2014
2000. Why is steering wheel difficult to turn?
Can depends if pulley pump was installed incorrectly or you have a bad rack. The best way to check if your pump is actually pumping is by crimping the return line with pliers careful not to cut it and listen for whine if no whine is heard pump is defective if whine is heard your rack and pinion is bad
Mar 07, 2016 | Dodge Ram 2500 Cars & Trucks
Whining power steering pump on 2001 bmw 740il
have you put a different type of power steering fluid?
in some instance, if they put a different type of fluid, the solution bubbles up and makes a whining noise when you use the car.
tnx 4 using fixya,
drcool
Oct 10, 2008 | 2000 BMW 7 Series
Can altenator sound like bad power steering pump?
Many new power steering pumps will exhibit a whining noise for a time after installation. Some won't. Typically, they quiet down within 2-3 weeks once they break in a bit. If the new pump is doing its job and not leaking and the whine is not more like an ear-splitting shriek, just wait it out and see what happens.
Feb 19, 2016 | Cars & Trucks
Power Steering Pump Whining?
Yes I think it would. It is probably the shaft bering faililng.
Jan 22, 2014 | SK Hand Tool Altenator / Power Steer /...
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
1994 chrysler lee baron fuel pump whining
You might try changing the fuel filter, most likely the fuel pump is going out and will need to be replaced.
May 13, 2010 | 1994 Chrysler LeBaron
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
2003 chevy silverado
A power steering pump will whine if it is low on fluid, when you turn the wheels you will hear the whine or if the power steering belt is to tight you will also hear the whine. You will not hear this whine when the truck is stopped.
Jul 24, 2009 | 2000 Chevrolet Blazer
Lincoln town car 2000 - whine in the rear
Hi this is a common problem for these cars the whine noise is coming from the fuel pump and once they fuel pump starts whining the life of that pump is very short the best thing to do is replace the fuel pump and your fuel filter it shouldnt cost much mainly under $100.
Anderias
Feb 03, 2009 | 2000 Lincoln Town Car
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Pool & Spa Logo
41 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
