Question about Mintek MDP-1770 Portable DVD Player
How to hook up portable dvd to tv - Mintek MDP-1770 Portable DVD Player
Magnavox portable dvd
If there is an output on the portable TV/DVD, connect a cable from the output on the portable to the input on the flat screen. If there is nothing labeled output on the portable, this is not possible. Sorry
Apr 09, 2014 | Televison & Video
HOW DO I HOOK UP RCA 9IN COLOR TV MODEL 9V345T TO A DVD OR VCR
With TVs, the cable connections (red, white and yellow) are usually on the back of the TV, but if they are on the front, when facing the TV, the spot to put in the cables are on the left side of the TV. with most all DVD and VCR players, the wire hook-ups are on the back, and are color-coded, idiot-proof, no offense, that was not directed to you.
Oct 01, 2010 | RCA 9V345T 9 in. Portable Television
Hi i want to know how to connect my gamecube to my portable dvdplayer
I'm going to assume you are trying to be able to play both gamecube and the dvd player on one tv. Not at once, but I'm guessing you think you can't hook both to the TV. If you no matter what big tv it is, you can connect it to your tv.
If your trying to connect the gamecube to the dvd player then you need to have inputs and outputs on the dvd player itself. hook the video and audio of the gamecube to the input of the dvd player and the ouput of the dvd player to the input on the tv
Aug 09, 2009 | Pyramat PM450WR for PlayStation 2,...
Hook up portable dvd player to tv
If you have component out jacks in the back (yellow, white, red plugs) you should be able to buy plugging them into your TV's Component IN jacks.
May 21, 2009 | Cyberhome CH-LDV 700B Portable DVD Player
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
I have the cord to hook up the portable to a tv.
Yellow-White and Red will hook to AV Input in TV and you can find same colors female pins at back of TV.
Nov 28, 2008 | Sony DVP-FX810 Portable DVD Player
I hooked up my portable dvd player to a vcr so i can watch tv on my dvd player and i can't see the picturebut i can hear the sound...
first off have you tried hooking something you know works up to the vcr and seeing if it works??
if you have and it does work then try hooking to portable up to a tv.
if it still doesnt work then its the player.
if it works on the tv then you have to assume its a copyright protection to keep you from recording dvds.
now if it doesnt work on the tv possible solution could be to make sure the cable is connected firmly, or replace it all together. you might also want to check to see if there is a switch to select the video output.
Apr 14, 2008 | Televison & Video
Connect dvd/cd player to GE OR OTHER BRAND TV
if you dont have the audio video imputs RCA jacks on your TV, you can hook it up through a RF MODULATOR you can hook up to any tv this way. they come with instructions as well as the magnavox also shows how to hook one up.
Dec 10, 2007 | Coby DVD-207 Portable DVD Player
Hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Nov 24, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Mintek MDP-1770 Portable DVD Player Logo
19 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
