Question about Toshiba BDX3300 Blu-Ray Disc Player
Close capsion will not go away - Toshiba BDX3300 Blu-Ray Disc Player
I want to add a lens to take better close ups from far away. What would be the product number?
If you want to take close-ups, you want the DMW-LC55 (and the DMW-LA1 adapter).
If you want to take pictures from farther away, you don't need any additional gear. Just get farther away from the subject then take the picture.
Dec 03, 2012 | Panasonic Lumix DMC-FZ7 Digital Camera
Tray opens then closes right away on its own
Sensor on the tray has fault. Open the tray and power off the system right away. Disconnect the power cord from the wall and then close the tray manually. Then connect power back on and see it will reset the sensor
Sep 28, 2011 | Audio Players & Recorders
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Oct 26, 2009 | JVC Televison & Video
Black box when tv is on and going through channels
This worked on my tv...give it a try:
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | JVC AV-36S33 36" TV
Close up shots won't auto focus.the lens trys to adjust but the final setting is out of focus. the camera works fine on subjects at least 2 feet away
try using the little throttle that is located just below your on/off switch. if you push that either up/down, it should help you manually focus your subject. It is actually a really fun feature to play around with.
Feb 28, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Window slowly rolls down when closed.
Terry,
It's seems your pc got to much junks or spyware in your system... need to cleaned out your browsing history, temporary internet files or scanned with virus software... Have a nice day!
Aug 18, 2008 | Gateway FPD2275W LCD Monitor
Big black box on screen
It has something to do with the closed captioning. He must have hit the closed caption button on your remote. You need to either turn the closed caption off or make another selection under closed captioning like cc1 cc2. Just keep making selections until the box goes away.
Jul 09, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba TV MV13P2
All I can say is that the black box appears when the closed captions are on and set to TEXT. This is normal. Turning off the closed captions should make the black box go away. If the closed captions are somehow turning themselves back on, there may be an issue with the microprocessor in your TV.
Aug 24, 2007 | Toshiba MV13P2 13 in. TV/VCR Combo
Toshiba BDX3300 Blu-Ray Disc Player Logo
22 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
