Question about Whirlpool WTW5600SQ
Will not agitate
Machine will fill but does not agitate no motor sound. will not drain water or spin out
  • 286 Answers
Check the lid switch to see if you ca hear clicking. If so it could be a bad lid switch or the timer can have a dead spot in it. Try advancing the timer alittle to see if that works. If so replace the timer.
Posted on May 19, 2009
My GE WCSR4170D AWW top loading washing machine will not stop filling with water. i can get it to agitate when i blow into the air line hose attached to the water level switch. BUT it never stops filling...
Thanks for choosing FixYa and welcome. You probably have a bad water level switch. As for the agitation, the drive motor controls the agitation, spinning, and draining. It is possible for the machine to not agitate, but yet spin and drain. The motor runs clockwise and counterclockwise. It may be bad and if so, will need changed.
Apr 30, 2011 | General Electric WCSR4170D Top Load Washer
You start the washer and the water will fill up to where it is suppose to but will not start to aggitate.The water will drain but the drum won't spin,than it will fill up again and it won't agitate...
Your drain hose is maybe too low and therefore gravity is draining out the washer OR the drain hose is too tight in the drain and a siphoning effect is happening.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 22, 2010 | Hotpoint Washing Machines
My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Jul 12, 2010 | Estate ETW4100SQ Top Load Washer
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
WASHER FILLS WITH WATER,MOTOR ENGAGES AND RUNS SMOOTHLY,BUT NO AGITATOR ACTION. WILL GO THRU TIME CYCLES AND FILL WITH AND DRAIN OUT WATER BETWEEN CYCLES. JUST NO AGITATOR. iT WILL SPIN DURING THE SPIN...
Sounds like you motor coupling has broken. The water pumps out so that tells me the lid switch is fime and motor is fine. The drive coupling mounted between the tranny and motor is probably broken
8a0970d.jpgI have a page with pics and movies to give ya some ideas what to do. HERE
Mar 11, 2009 | Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
Whirlpool WTW5600SQ Logo
98 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
