Question about Brother Sewing Machines
When i turn on my brother pe 770 the screen is blank only won't do anything
  • 59 Answers
SOURCE: Brother Original Card Substitute
for the machine I'm pretty sure any card would work as long as it's using .PES file types. for the card reader on the compupter it would take the original card
Posted on Mar 27, 2010
SOURCE: I have a brother pe-770
unwind it by hand onto another bobbin or empty spool
Posted on Nov 23, 2010
  • 2069 Answers
SOURCE: Brother 770-PE I have Amazing Design software and
well, from what is indicated in the USB manual for your Brother, check that none of the below issues is causing this.
- Ensure that USB media contains data for no more than 200 embroidery patterns since Embroidery patterns cannot be transferred to the machine if the USB media contains data for more than 200 embroidery patterns. If this is the case, reduce the number of designs saved on the USB media.
- if the embroidery designs contain too many colors (this number may vary within the designs themselves), it may not be possible to transfer an embroidery pattern to the machine, even if there are less than 200 embroidery patterns that have been saved on the USB media. In this case also, reduce the number of designs saved on the USB media.
- Save the patterns in the root directory of the USB media. If embroidery data is saved in a folder on USB media, that embroidery data cannot be retrieved by the machine.
thanks for using fixya
Posted on May 27, 2011
  • 17 Answers
SOURCE: I have a Brother PE 770 and I can not get the
Just ask the experts if you do not want to bother. but if want to improve yourself, then do it carefully and patiently. would be fine.
Posted on Aug 14, 2011
  • 12 Answers
SOURCE: How to oil brother PE 770
Brother says it should not be oiled but having 14 of those, I know that it has to be done but a Brother technician will not do that. OILING the machine may cause F05 speed sensor error. See how to solve it under this label.
U need to remove the complete front plastic panel. 3 screws on the top (2 lower the handles, 1 at upper right. Remove 1 screw at the center bottom of the rear panel. Remove both left top/ bottom panels (1 screw each) then the horizontal bottom left panle (2 screws). All the balance is fixed with clips.
First undo the 2 clips under the machine than carefully unclip everywhere. Front panel have 2 wire assembly attached to main board. Regular one is easy to remove. To remove the flat one, send down the upper part of the attchment on the main board.
Don't use reg. thin white sewing machine oil, it evaporate. Use SAE 80 (differentail type) oil or something like taht. Lubrificate all 4 lower shaft supports, rotary hook gears and central pin (from the top, under the bobbin case). Then lubrificate all the upper shaf support and especially all the needle bar mechanism. U need a good light to see upper needle bar support. Lower needle bar support support is the most critical point.
Posted on Jul 07, 2012
Brother pe 770 brand new with this error message F02 SS SW ON
Brand new? Take it back where you bought it. It is a defective unit.
Mar 01, 2017 | Brother PE-770 Embroidery Machine
My CS 770 displays a flashing F4 Brother sewing machine
Perhaps this will help:
https://answers.yahoo.com/question/index?qid=20120713084921AAH7Vxl
Not much information on a Brother C4 error. You might try contacting Brother Support. Support Center
Jun 13, 2016 | Brother PE770 PE 770 Embroidery Machine w/...
My Brother PE-770 presser foot Q has started making a clacking noise. If I press in on the lever on the back of the foot, the clacking stops. What is causing this loud noise and how do it fix it?
Sounds like something in the machine in the head that makes it go up and down. either wear or something loose. I would have it checked by a Brothers repair shop
Jan 10, 2015 | Brother PE-770 Embroidery Machine
I need to rotate my pattern by 45 degrees on my brother pe 770. I've tried going to layout but it only does 180. Any ideas?
Get software such as Embird Design to do it and then export the .PES file and transfer to the machine. Unfortunately the low end machines do not have this capability.
Apr 02, 2013 | Brother PE770 Computerized Sewing Machine
What kind of plug/cord do i use to plug my Brother PE-770 into my computer
Just use a regular printer type cable. On newer models, they use a regular USB connection so it's easier to use USB keys
Jan 29, 2012 | Brother PE770 Computerized Sewing Machine
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
