Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
I have a Seagate Free Agent M Series 750 GB external hard drive. In using it yesterday, I connected to my computer and it was fine. After about 20 minutes the unit shut itself off and now has no power to the system. Was hoping you would have a fix for this
  • 696 Answers
First step, check the power cord, if you have a multi meter, set it to the 20v range DC and test the AC adapter for voltage.
If it is dead you may be able to get a replacement but it's likely cheaper to move the drive into a new enclosure(see the next step)
Stop in at your local computer store, ask the techs to sell you a SATA HDD enclosure and either move the drive into it for you, or if your feeling handy take it home and give it a try yourself(this WILL void Seagates warranty)
Once the drive is in the new enclosure, hook it up to the computer and see if it works, if so you're done. If not, send it to a pro for data recovery. In North America I always recommend Armot-IT Data Recovery(in FixYa Database), if you're in another region add a comment here and I will make an appropriate recommendation.
Hope this helps FixYa,
Chris
Posted on May 20, 2009
Hi,how can i format my seagate freeagent goflex 750 to fat32 ?
Welcome to Fixya. Once you connect the harddrive on the computer go to my computer or computer then right click on the seagate drive then select format. On the window that will pop out on the screen select Fat32 then format the drive. Please use windows xp or 7 because vista don't have fat32 but exfat.
Thanks
Jul 17, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
Just bought the GoFLex Pro 750 GB. I have two PCs, both on XP... neither can see the HD via my computer... I have done a check via computer managment and it says the HD is fine... but it is not...
Hi, Thanks for using fixya.
Remove any usb devices from your computer other than your Free agent then reboot the computer see if it is reconized and it is useable. Then plug in your other devices one at a time make sure you see the Your device is ready to use. If your Free Agent is not reconized got to Seagate.com search for your device driver. Remember when you want to pull out any usb device make sure you remove it throught windows first. Fastest way is to go in My Computer or Computer right click on the device and choose eject. After the name changes to removable device it is safe to pull our.
Hope this helps,
Terry
Feb 17, 2011 | Seagate FreeAgent GoFlex Pro 750 GB USB 30...
MY Seagate Free Agent Pro 750GB External Hard drive is no longer registering on my computer. It's only about 1/3 full and I need to recover the data. The software on my computer does not detect a free...
Sounds like the enclosure has a problem. If this is one of those free agent go flex drives with the removable USB to Sata interface you might try getting another drive like it and borrow the interface from that drive when you need to use this one. That's something I have to do now because one of my interfaces died also.
Jun 30, 2017 | Seagate ST307504FPA1E3-RK FreeAgent Pro...
Just got a seagate free agent go 640gb and it didn't come with a manual or cd. loads on the computer fine but no icon or way to access it.
No external hdd has a cd or a manual, cause their is none required for it. It is as simple as using a flash drive. You need to go into My Computer (if using XP ) or Computer Window ( if using Vista or 7 ) and when you connect the Seagate to the computer you will be able to see an option poping up under removable storage devices. If it does not come up then return the product, its bad.
May 04, 2010 | Seagate FreeAgent Go 640GB External USB 20...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
May 10, 2008 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
221 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
